Upgrading a CO2 Laser with the Think3DPrint3D Duet controller June 13, 2015 06:38PM |
Re: Upgrading a CO2 Laser with the Think3DPrint3D Duet controller June 16, 2015 02:01AM |
Re: Upgrading a CO2 Laser with the Think3DPrint3D Duet controller June 24, 2015 03:27AM |
Re: Upgrading a CO2 Laser with the Think3DPrint3D Duet controller June 26, 2015 05:40PM |
T3P3
Fantastic Work Radian
You can get PWM out of the FAN 0 FET. For example if you set the fan speed using M106 SNNN from 0-255.
Cheers
Tony
Re: Upgrading a CO2 Laser with the Think3DPrint3D Duet controller August 23, 2015 05:04AM |
Re: Upgrading a CO2 Laser with the Think3DPrint3D Duet controller August 23, 2015 10:10AM |
Hi Jelle, thanks for the pointers to those Gcode generators. The firmware for the duet controller syncs the fan output to extrusion moves so I'm already covered. As for power control, I didn't expect it to work so well as it does with a fixed (no PWM) power level. The kinematics of the duet firmware seems to maintain a constant velocity regardless of head travel - as far as I can tell by lasering card at low power and carefully inspecting the results.Quote
Jelle
On the firmware side I think you need a way to control the laser. It is probably best to hijack the E coordinate for that, as it already is moving in sync with the other axes, so it is not that hard to implement ppi or ppm (pulses per inch/mm). One thing cheap lasers usually get wrong is the 'corner power': the laser power stays constant and removes more material in the corner when decelerating/accelerating.
But how far did you get with this project?
Re: Upgrading a CO2 Laser with the Think3DPrint3D Duet controller August 23, 2015 01:38PM |
Re: Upgrading a CO2 Laser with the Think3DPrint3D Duet controller July 31, 2017 05:18PM |
Re: Upgrading a CO2 Laser with the Think3DPrint3D Duet controller August 03, 2017 05:18PM |
Re: Upgrading a CO2 Laser with the Think3DPrint3D Duet controller August 04, 2017 06:15AM |
Re: Upgrading a CO2 Laser with the Think3DPrint3D Duet controller August 04, 2017 06:40AM |
Re: Upgrading a CO2 Laser with the Think3DPrint3D Duet controller February 18, 2022 11:14AM |
Re: Upgrading a CO2 Laser with the Think3DPrint3D Duet controller February 18, 2022 11:41AM |
Re: Upgrading a CO2 Laser with the Think3DPrint3D Duet controller March 05, 2022 04:03AM |
