Marlin firmware as laser cutter August 12, 2015 09:05PM |
Re: Marlin firmware as laser cutter August 13, 2015 12:30PM |
Re: Marlin firmware as laser cutter August 14, 2015 10:20AM |
Re: Marlin firmware as laser cutter August 15, 2015 04:21PM |
Re: Marlin firmware as laser cutter August 16, 2015 07:22PM |
Re: Marlin firmware as laser cutter August 16, 2015 10:55PM |
Re: Marlin firmware as laser cutter January 13, 2016 01:09PM |
Re: Marlin firmware as laser cutter January 13, 2016 01:37PM |
Admin Registered: 16 years ago Posts: 13,888 |
Re: Marlin firmware as laser cutter January 13, 2016 03:42PM |
VDX
... AFAIK the fan output is a PWM signal, so with a multimeter you'll see the averaged voltage only.
You need an oszilloscope to see/measure the exact timings and voltage levels ...
Re: Marlin firmware as laser cutter January 13, 2016 04:15PM |
Re: Marlin firmware as laser cutter January 13, 2016 05:03PM |
Re: Marlin firmware as laser cutter January 13, 2016 05:19PM |
Re: Marlin firmware as laser cutter January 13, 2016 05:44PM |
Re: Marlin firmware as laser cutter January 13, 2016 06:31PM |
Re: Marlin firmware as laser cutter January 13, 2016 07:01PM |
Re: Marlin firmware as laser cutter January 13, 2016 07:33PM |
Re: Marlin firmware as laser cutter January 13, 2016 09:47PM |
Re: Marlin firmware as laser cutter January 13, 2016 10:42PM |
Re: Marlin firmware as laser cutter January 14, 2016 03:26AM |
#if MB(RAMPS_13_EF || MB(RAMPS_13_EFF) || MB(AZTEEG_X3) || MB(AZTEEG_X3_PRO) #define FAN_PIN 6 // was D9 #else #define FAN_PIN 4 // IO pin. Buffer needed #endif
// Increase the FAN pwm frequency. Removes the PWM noise but increases heating in the FET/Arduino //#define FAST_PWM_FANin configuration.h to get smoother grayscale results.
Re: Marlin firmware as laser cutter January 14, 2016 03:37AM |
I presume anyone who has this working is using an adjustable current TTL enabled laser diode driver am I right? That would allow using the D9 block to power the laser. I also presume with such driver the voltage of D9 being higher than whats typically recommended isn't too big of a problem as long as you have proper cooling on the driver and diode right?
Re: Marlin firmware as laser cutter January 14, 2016 01:06PM |
o_lampe
If you want to use M106/M107 commands with a 5V signal level, search Marlins code for "EFB" in all tabs until you find this piece of code in pins.h.
Change it to any servo pin you like ( mine is at pin 4 ) and connect it to the TTL input.
I also defined
Be aware that with red DVD LDs, grayscaling is almost impossible. ( at least on light colored surfaces )
Maybe if you find a program that allows to scale the PWM between user-selectable XXX-YYY instead of 000-255. ( I'm working on rewriting "305 Engineering"s inkscape extension. )
-Olaf
Re: Marlin firmware as laser cutter January 15, 2016 03:39AM |
Re: Marlin firmware as laser cutter January 15, 2016 12:26PM |
Re: Marlin firmware as laser cutter January 15, 2016 01:44PM |
Re: Marlin firmware as laser cutter January 16, 2016 03:28AM |
Re: Marlin firmware as laser cutter January 16, 2016 12:51PM |
Re: Marlin firmware as laser cutter January 17, 2016 03:59PM |
Re: Marlin firmware as laser cutter January 18, 2016 12:30AM |
Re: Marlin firmware as laser cutter January 18, 2016 11:07AM |
Re: Marlin firmware as laser cutter January 18, 2016 11:26AM |
