Need advice before connecting TTL laser driver to prusa i3 April 08, 2016 01:05PM |
Re: Need advice before connecting TTL laser driver to prusa i3 April 08, 2016 02:51PM |
Re: Need advice before connecting TTL laser driver to prusa i3 April 08, 2016 03:04PM |
Re: Need advice before connecting TTL laser driver to prusa i3 April 08, 2016 03:19PM |
Re: Need advice before connecting TTL laser driver to prusa i3 April 08, 2016 03:35PM |
Re: Need advice before connecting TTL laser driver to prusa i3 April 08, 2016 04:01PM |
Re: Need advice before connecting TTL laser driver to prusa i3 April 08, 2016 04:25PM |
Re: Need advice before connecting TTL laser driver to prusa i3 April 08, 2016 05:08PM |
Re: Need advice before connecting TTL laser driver to prusa i3 April 09, 2016 02:00PM |
Re: Need advice before connecting TTL laser driver to prusa i3 April 10, 2016 09:02AM |
Re: Need advice before connecting TTL laser driver to prusa i3 April 10, 2016 09:13AM |
Optically isolated input = it's ok with a N-fet, no ground issues. I think they have realized the problem with D9.Quote
jtech
The input connection provides an optically isolated input for control of the laser diode. The connection and the jumper settings were described in the previous sections. The voltage required to turn on the opto-isolator is 2.8 volts. The input can handle up to 36 volts at no more than 50 ma. The input can be cycled with no degradation up to 5KHz.
Re: Need advice before connecting TTL laser driver to prusa i3 April 10, 2016 04:28PM |
Re: Need advice before connecting TTL laser driver to prusa i3 April 10, 2016 06:12PM |
Re: Need advice before connecting TTL laser driver to prusa i3 April 12, 2016 03:21PM |
Re: Need advice before connecting TTL laser driver to prusa i3 April 13, 2016 03:01AM |
