Laser mirror and lens allignment April 29, 2016 02:33AM |
Re: Laser mirror and lens allignment April 29, 2016 02:53AM |
Re: Laser mirror and lens allignment April 29, 2016 03:01AM |
falwty99
If you have a head with adjustable length the beam should be in the centre of the lens at the shortest and the longest distance. That is what is important. Adjust the third mirror so this happens.
Re: Laser mirror and lens allignment April 29, 2016 03:33AM |
falwty99
If you have a head with adjustable length the beam should be in the centre of the lens at both the shortest and the longest distance. That is what is important. Adjust the third mirror so this happens.
Re: Laser mirror and lens allignment April 29, 2016 07:27AM |
Re: Laser mirror and lens allignment May 02, 2016 02:15AM |
falwty99
You are on the right track, absolutely. Here is what I do.
Remove the lens. Adjust to shortest length. Put a paper at then end of the now open tube. Pulse the laser.
Then do the same with the head at its longest distance. When the laser dots are in the middle of the tube in
both the upper and lower position - then its good. Put lens in, adjust focus and run the laser.
The beam is perpendicular to lens and in the middle.
