Laser cutter/engraver needs 5v PWM - I use Marlin and MKS GEN 1.3 August 26, 2016 02:17PM |
Re: Laser cutter/engraver needs 5v PWM - I use Marlin and MKS GEN 1.3 August 26, 2016 02:45PM |
Re: Laser cutter/engraver needs 5v PWM - I use Marlin and MKS GEN 1.3 August 26, 2016 03:16PM |
Admin Registered: 16 years ago Posts: 13,873 |
Re: Laser cutter/engraver needs 5v PWM - I use Marlin and MKS GEN 1.3 August 27, 2016 02:35PM |
Re: Laser cutter/engraver needs 5v PWM - I use Marlin and MKS GEN 1.3 August 27, 2016 03:14PM |
Re: Laser cutter/engraver needs 5v PWM - I use Marlin and MKS GEN 1.3 August 27, 2016 03:19PM |
VDX
... I'm using different pins - either AUX/servo, or the E-Step-pins, or any other free, available pin, if needed.
To define the correct TTL-voltage and/or polarity I'm using 74HCT14 Schmitt-trigger+inverters to either invert or only drive (with double-inverting) it.
For other common voltages like +10V / 24V / 48V I'll add fast optocouplers and redefine the input or output voltages - so no problem to interface industrial gear ...
Re: Laser cutter/engraver needs 5v PWM - I use Marlin and MKS GEN 1.3 August 27, 2016 03:28PM |
Re: Laser cutter/engraver needs 5v PWM - I use Marlin and MKS GEN 1.3 August 27, 2016 11:18PM |
Re: Laser cutter/engraver needs 5v PWM - I use Marlin and MKS GEN 1.3 August 28, 2016 03:49AM |
Re: Laser cutter/engraver needs 5v PWM - I use Marlin and MKS GEN 1.3 August 28, 2016 03:42PM |
Re: Laser cutter/engraver needs 5v PWM - I use Marlin and MKS GEN 1.3 August 29, 2016 12:58PM |
Re: Laser cutter/engraver needs 5v PWM - I use Marlin and MKS GEN 1.3 August 29, 2016 01:11PM |
