deep cutting wood
Posted by philr
deep cutting wood
October 01, 2016 09:46AM
I have not seen this question and am hoping that someone might be able to provide an answer.
A client wants me to laser a sign made of wood (California redwood). He has had signs in the past made using a router and has not been pleased. However he does like the "deep" grooves that the routers make.
In the past I have made deep laser cuts using a series of passes. Unfortunately in some cases the surrounding surface wood was scorched.
Am I better off reducing the number of passes by increasing the power and reducing the speed, or am I better off using the normal settings and making more passes? Also, will masking the top of the wood help or hinder the process?
Re: deep cutting wood
October 01, 2016 01:52PM
Look at how the material is removed
Laser burns (scorches) off material --- does not shear off material
Perhaps air (nitrogen) assist (high pressure)
but burn wood in abscence of oxygen = charcoal
Surface sanding will rid the scorch from outside the letter
Show me a wood laser cut that is not burned black
spray paint --- surface sand
philr
confused smiley
VDX
October 01, 2016 04:09PM
... look in the video here - [vimeo.com]
I've engraved with lower power (shorter pulses) and only minimal fume traces ... and before cutting with highest power I've coated the wood with package tape to prevent fuming ...
Viktor
October 01, 2016 10:00PM
VDX
what laser what machine
what is gieLAS?
confused smiley
VDX
October 02, 2016 12:10PM
... the lasrdiode is a blue 3.5W-diode, but it's nearly the same with a 2W-diode.
The machine is a "refurbished" CNC-mill - but I'm using (refurbished and DIY-built) several other machines too, even 3D-printers ....
My companies name is "Gie-Tec", so I've named the laser module "gieLAS" -- and a heavy modified Pronterface with special plugins for pastedispensing (and laserengraving) "gieCAPS" winking smiley
Viktor
