How safe are safety glasses?
Posted by Cyclonit
August 27, 2017 01:00PM
this may be a stupid question for many of you, but I am at the very beginning of my research regarding laser engravers/cutters and was wondering how safe safety glasses actually are. I am aware that there are many sunglasses which don't block all UV light, thus I am wondering if laser safety glasses are capable of blocking out all of the harmful light or if its more of a "if you see a bright light, turn away fast" kind of deal. Especially when dealing with something like a 40W laser, I wonder if they can ruin your eyesight through safety glasses, if one does not look away immediately.
Kind regards,
Cyclonit
VDX
Re: How safe are safety glasses?
August 27, 2017 01:29PM
... the "safety level" is normally given by the "OD"-values printed on the side of the goggles - look here for declaration and comparisons:
[www.thorlabs.de]
This OD-values are different for different wavelengths - so you have to select the goggles specifically for the laser and application you're targeting.
But be careful! - there are some goggles in the market with "faked" OD-values too eye rolling smiley
Viktor
Aufruf zum Projekt "Müll-freie Meere" - [reprap.org]
August 28, 2017 01:31AM
If you refer to a 40W CO2 laser, you won't see it coming. It's very short UV wavelenght.
Good news is, any clear plastic cover will absorb stray light.
VDX
August 28, 2017 02:37AM
... no, the wavelength of a CO2-laser is the opposite direction winking smiley -- it's far, far IR @ 10640nm.
And yes, this wavelength won't pass any of the goggles -- you can shield it totally with any glass or acrylic ...
Viktor
August 31, 2017 02:13AM
...I knew it was invisible winking smiley
December 01, 2017 11:17AM
I am a brand new 10 watt CO2 laser owner, well I bought one but it is still in the mail. I am brand new to anything concerning lasers.
I am "thinking" of building a enclosure, would acrilic or transparent plastic be safe for construction? I'd like to be able to see the laser working.
I have the safety glasses ordered for the laser, for my own use but what about other people.
If I make the enclosure large > 3' x 3' I probable would mount it outside.
Is there a "Getting Started" thread?
VDX
December 01, 2017 11:53AM
... the CO2-laser beam will be absorbed totally by any acrylic or glass enclosure - so yes, it would be safe ... as long the beam won't hit the shielding directly! -- then it would slowly burn through ... or, when using glass, it can crack because of the thermal stress ...
Viktor
December 01, 2017 01:25PM
Thank you Viktor, there will be so many questions coming up.
Ralph
