help with cheap china laser 5.5W
March 09, 2018 05:27AM
A month ago I got a cheap china laser engraver see [www.ebay.com.au]
It had no instruction on how to build it ,but I had built one before (300mw laser), the problem is that the control board get very hot and the solder melts. so I believe its the wrong control board for the 5.5w laser.
I would like to use an Ardunio uno and cnc v3.0 shield, but need to drive the 5.5w laser form it.
Can anyone help on how to do it ?
VDX
Re: help with cheap china laser 5.5W
March 09, 2018 05:41AM
... first -- the "5.5W" is the driving "power" of the diode, not the optical output energy!
from the transaction:
Support Power: 100mw-5500mw
Power supply:5.5W
- so get the info from the vendor about diode type and the "max. safe working" current - not the "max. rated"!
Then -- get a proper current driver for this diode
... and last, read through all the hundreds of threads with similar questions or hints for proper driving laser diodes ...
Viktor
Aufruf zum Projekt "Müll-freie Meere" - [reprap.org]
March 09, 2018 06:38AM
.". first -- the "5.5W" is the driving "power" of the diode, not the optical output energy! "
I took the fan of the top of the Laser to see what voltage is , its 12v, it get its power from the same terminals as the laser board.
so at 12v 5.5w i should only be drawing P/ V = A .. 5.5w / 12v = 0.458 amps ?
Edited 2 time(s). Last edit at 03/09/2018 06:46AM by baloo.
VDX
March 09, 2018 09:39AM
... no! - there is a constant current chip in the driver or inside of the diode cooler housing.
With "5.5W" power this could be a 2W-diode, which is specified with 1.5A at 3.7V, what multiplicated gives 1.5 x 3.7 = 5.55W! ... the remaining voltage from the operating point (here 12V - 3.7V = 8.3V) will be transferred into heat -- 1.5A x 8.3V => 12.45 Watt excessive heat ... this can easily melt your electronics!!!
The types variants are between 3.7V to 5V, so the current (and optical output) could be lower, or a different diode type ... get the essential infos ... or try your luck ...
Viktor
March 09, 2018 01:25PM
Thanks Viktor
I have been trying to contact the vendor for a month now, they do not answer me, so I'm flying blind here.
I'm not any good at electronice, (i'm a retiered shipwright ) smiling smiley
The only info I have is
Working Voltage DC 12V
Laser Module
Power supply:5.5W
Wave Length:450nm
my option is to use a large Mosfet to handle the current and heat ??
Edited 2 time(s). Last edit at 03/09/2018 02:10PM by baloo.
VDX
March 09, 2018 03:52PM
... you can open the diode housing and scrap out all the silicone - could be, the constant current chip is "embedded" inside.
Remove it, solder two wires to the diode and search a new driver with proper documentation ...
Viktor
March 09, 2018 05:07PM
see attachments that is all I can see
in photo 1 the red black green an blue are the 12v in, the blue and green go starte to the fan.
in photo 2 the resd and yellow go start to the diode
Edited 2 time(s). Last edit at 03/09/2018 05:15PM by baloo.
open | download - WIN_20180310_07_53_36_Pro.jpg (488.8 KB)
open | download - WIN_20180310_07_53_50_Pro.jpg (505.1 KB)
open | download - WIN_20180310_08_01_35_Pro.jpg (393.9 KB)
VDX
March 09, 2018 05:42PM
... it seems, the board is the constant current driver (set/defined by the trimpots) - so only the wires to/from the diode, what's better than a separate CC-chip.
If you can't get/find infos for your driver, then drop it and search one with available infos ...
Viktor
March 09, 2018 05:50PM
Thanks Viktor
March 09, 2018 10:25PM
I have an arduino with a cnc v3 shield moving the head around.
I put an led on the spindle speed output and can turn it off and on, and dim it.
is there a way to use this to turn the laser off and on via mosfet etc ?
