Issue with grayscale raster images
Posted by Septora
January 04, 2019 08:04AM
Hi.
I have built up a new laser system and having an issue with etching raster pictures on my mediums.
I have a RAMPS 1.6 with Arduino DUE. Been using Repetier's firmware and have tried MarlinKimbra.
So far, I have no issues with either firmwares with movement, endstops, or firing the laser at different intensities. I can cut and do outlines and monotone drawings.
But when I run a raster setup, it keeps passing over the same row and never advancing to the next Y cordinate. I see the movement command in the gcode.
I use LaserWeb as my interface and can see the drawing from the gcode script show in the preview correctly. I use Inkscape and tried different extensions to prepare the image and get the same result.
Probably missing a simple item somewhere. Anyone seen something similiar?
I am at work now, but can upload the gcode later when I get off if that will help.
Edited 1 time(s). Last edit at 01/04/2019 08:05AM by Septora.
