Laser cutter from 3D printer wiring issue
Posted by Gorebar
July 27, 2020 05:19AM
Hi there;
I am trying to convert a 3D printer to laser cutter.
I got this laser module bought from Aliexpress:
[es.aliexpress.com]
I am trying to convert a TEVO TARANTULA 3D printer.
The motherboard is MKS Base v1.2:
[gr33nonline.files.wordpress.com]
I tried to connect the wires to fan plug in the motherboard and the power supply and the laser turns on, but I can't turn it off using Gcode codes (M106/M107). This codes are enabled in firmware (I tested it using a simple fan, and it works) so i guess the problem is with the laser module connections.
This is my connection scheme on attached image
Would you help me to solve the problem?
Best regards.
Álvaro
Edited 2 time(s). Last edit at 07/27/2020 05:21AM by Gorebar.
open | download - Scheme.png (873.6 KB)
Re: Laser cutter from 3D printer wiring issue
July 27, 2020 05:46AM
You cant connect -ve line to power supply -ve
the mosfet switches the -ve line. when you have it wired to the supply -ve it is always on.
I would also expect ttl to be 5v not 12v...
Edited 1 time(s). Last edit at 07/27/2020 06:00AM by Dust.
July 27, 2020 06:10AM
I would try 12v - and + directly to the laser module 12v pins
the 3rd pin I would connect to a pwm capable line eg D11 or D12 on the servo pins and in your firmware set FAN_PIN 11 so you can control it with m106.
but im quite worried you have destroyed the ttl pin with 12v
Edited 1 time(s). Last edit at 07/27/2020 06:12AM by Dust.
July 27, 2020 07:14AM
Hi Dust!
So... to keep safe (anything LOL).
I am a really noob with that, this is my new scheme (attached file). Thats right?
PS: The TTL pin looks good btw hahah
Thanks
open | download - Scheme.png (786.2 KB)
VDX
July 27, 2020 10:05AM
... check the +/- pins on your laser module!!
Viktor
July 28, 2020 05:08AM
Yeah VDX, I checked and looks correct. But I am not sure what is my problem.
I going to change what Dust told me about pin D11.
I'll write again with news.
Thanks!
July 28, 2020 06:07AM
the board seems to indicate that gnd is first pin, +12v is second pin, ttl is 3rd pin.
In your diagram you have first pin as 12v second pin as gnd and third pin as ttl.
July 28, 2020 06:12AM
You are right. My fault drawing the diagram. But its correct in real life LOL.
I'll test then!
Thanks!
August 04, 2020 05:49AM
Well... Thanks for your support! It's working good right now.
January 16, 2022 05:33PM
Thank you for the wiring diagrams Gorebar, This is what I have been missing. I have a laser module that is PWM but other than that it has the same labeled pinout on the laser board:
12 G P
V N W
+ D M
and was not sure how to wire it to the RAMPS 1.4
I will be putting the 12V+ to D9+ the GND to D9- and PWM to D6+
Someone please stop me if I have this wrong, I have already burned an Arduino from miswiring and melted 4 ft of wire trying to figure it out. Your images have really helped.
I will ley you know if I got it all working once the new Arduino comes in.
