3D Printers & Services in india.
Posted by kamalnv
May 02, 2014 06:23AM
Hi all,
I was browsing across the indian sites for 3D Printer Kits and Services, What i found was astonishing, literally all metros have 3D Stores in them dealing with either the kits, pro printers & Accessories.
Below is the list hopefully someone will find it helpful... If you find any others websites pls feel free to add..
[www.3dprintronics.com] - Prusa i2 & Prusa i3 Kits
[makemendel.com] - Plusbot, Rapidbot, megabot kits
[www.amptronics.com] - prusa i2 kit
[www.3ding.in] (redd robotics) - PrintrBot simple, Prusai3
[reprap-india.com] (aSensar) - components only
[rapid-innovation.webs.com] - Prusai3 (20K) & Custom all metal (30K)
[3dprotomaker.com] - Custom design @ 36K
[evotekrobotics.com] (karan) - Evotek Graber i3 (Improvised Prusa i3) - 34K
[www.protoprint.in] - custom all metal.
[www.ahagadgets.in] - Custom - Procentre999
[www.3dsense.in] - Pune 3DPen., Pro - 1.1L
[www.cycloid.in] - CSM1
[www.jgrouprobotics.com] - Pro printers 2.75L + wide range of PLA
[in.element14.com]) - Cube 3D imported by element14.
[danuc.in] - Spares only.
[www.brahma3.com] - bangalore
[www.3digiprints.com] - Bangalore
[www.c4l.in]
[meeccon.com]
3dPrinting Service
[www.3dhubs.com] - community based printing
[arttsy.com] - hyderabad.
[www.3digiprints.com] - Mumbai
[www.clarity3dprinting.com]
[kadkraft.com]
[blukraft.com]
[www.iprint3d.co]
[3dlabs.in]
[dfthreed.com]
Re: 3D Printers & Services in india.
May 26, 2014 05:52AM
Thanks for taking the time and effort to put this list together.
I've previously found [subassembly.in] offering filament and components. I think they're based in Bangalore but deliver everywhere.
May 29, 2014 10:55PM
New I3 personal Printer (semi -assembled Kit) for Rs 46,999
Technical parameters:
Positioning accuracy: Z axis 0.012mm XY axis 0.004mm
Print precision: 0.1-0 .2 mm
Thickness: 0.2-0.4mm
Build Size: 200 * 200* 200mm
Nozzle diameter: 0.4mm
Power: 220W
Voltage: 110V-220V
Best ambient temperature: > 25 ° C
Material filaments: ABS, PLA filaments
Material color: several colors such as white,green,red and so on
Material Specifications: Diameter :1.75mm/3mm
Movement of shaft speed: 40mm / s
Nozzle flow rate: 24cc / hour
Recommended the sprinklers temperature: 185° c (PLA)/230 ° c(ABS) (highest can be set to 260 ° C)
Heated the baseplate temperature : 110-120 ° C (winter appropriate warming, proper cooling in summer)
Other parameters:
Print head Quantity: 1
Equipment size: 360 *400*400mm
Package size: 500*460*530mm
Visit website below for more info
[www.3dsense.in]
Cheers
Rohan
9823788090
3d sense
Pune
open | download - 1183489108_226.jpg (57.7 KB)
open | download - 1188101296_256.jpg (72.9 KB)
open | download - New Image.jpg (427.5 KB)
May 25, 2015 09:27AM
Good list and i came across these companies and hope it will be useful
CADD centre 3D Printers - Plasto, envisiontec & 3d systems
CADD Centre 3Design - jewellery designing
iKix 3D Prints - 3d printing services
May 26, 2015 07:54AM
Refer Site : [makemendel.com]
You will get all size of build area and its accessories from one stop.
