RepRap Cyclone PCB Miller Parts in India
Posted by kaustubh
March 21, 2016 05:25PM
I am trying to build my second reprap machine, a Cyclone PCB Miller. Can you please provide an quote for the following items. (partially taken from [github.com])
I would also be interested in acrylic cutting services.
The bill of material is as follows:
SCREWS
M3x18mm 43
M3x10mm 16
M3x20mm 4
M3x8mm 6
M3x25mm 5
set/grub screw M3x4mm 3
WASHERS
M3 8
M8 6
NUTS
M3 67
M8 11
locking M8 2
BEARINGS
LM8UU 11
B608ZZ 5
SMOOTH RODS
8x210mm 2
8x150mm 2
8x250mm 2
THREADED RODS
M8x205mm 1
M8x290mm 1
M8x95mm 1
MISC
Endstop switch 2
Spring (roughly length:15mm, Ext Dia:11mm, Wire: 1mm, Turns:5)
Silicone tube 12x16x50mm 1 meter
NEMA 17 motor 3
Cable guide tube 1 meter
Probe cable (w/ crocodile clips) 1
Can you direct me to a dealer that can provide me with ALL the parts needed.
Thanks.
Edited 1 time(s). Last edit at 03/21/2016 05:27PM by kaustubh.
