generating gcode file from stl and obj file by CMD command prompt in windows 10
Posted by debakanta
August 18, 2016 09:13AM
Installed with Cura-15.04.3 and want to generate gcode by CMD command prompt in Windows
While running CuraEngine -s "C:\path\to\STL File\" I'm getting the below output:-
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU Affero General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU Affero General Public License for more details.
You should have received a copy of the GNU Affero General Public License
along with this program. If not, see [www.gnu.org].
Default config 'default.cfg' not used
M107
G1 F2700 E-4.50000
G0 F9000 X0.00 Y0.00 Z5.00
M104 S0 ;extruder heater off
M140 S0 ;heated bed heater off (if you have it)
G91 ;relative positioning
G1 E-1 F300 ;retract the filament a bit before lifting the
nozzle, to release some of the pressure
G1 Z+0.5 E-5 X-20 Y-20 F9000 ;move Z up a bit and retract filament even more
G28 X0 Y0 ;move X/Y to min endstops, so the head is out of
the way
M84 ;steppers off
G90 ;absolute positioning
Please let me know how can I get a correct gcode file
Thanks & Regards,
Debakanta
How to print a stl file or its gcode from windows command prompt?
Thanks & Regards,
Debakanta
