Hompages 3DLSX1
3DLSX1 is a software that allows a G-code based 3D printer and a camera-laser module, which you customize it yourself individually to generate point clouds.
The size of the objects is defined by the capacity of the 3D printer.
By using the X axis as an independent 3D scanner you have unlimited possibilities. The data generated can be used by third party software for CAD and / or reproduction.
after the calibration and adjustment of the system it is easy to scan
Only the X-axis scanner pure.
The accuracy of the scanner depends on the components of the camera, laser and the calibration.
Resolution in the direction of motion axle adjustable from 0.25 to 2.00 mm
We are currently working on English manuals and instructions.
Edited 1 time(s). Last edit at 11/20/2013 04:39PM by KK3DM.
