photogrammetry - how to get complete solid model
March 19, 2015 09:57AM
I'm just exploring this area and have a fundamental question that I'm sure others have solved.
As an example I have a badly corroded flange which is a part from a boat and the part is not commercially available.
I want to create a 'master' for molding, so have scanned the object and edited to have a visually correct 3D object in DesignSpark PCB, Autocads 123 and Meshmixer.
Here I'm stuck! The part has a hole where it was sitting during to the photography, so now realise I need to repeat it in a better fashion to get all of the 3D data and will repeat by balancing it on three spikes (which I can subsequently delete, but how do you fill the remaining holes?
Other questions/comments:
It's interesting to me on this first experence in this area in that you obviously create a surface and in any hole you can visualise the inside of the object. Fascinating, but how do you go to the next step of printing a replica? Does the object print as a solid or is this also another step in the process?
Also having scanned the object is there a method of editing such that the corrosion pits and scratches are removed/filled? Obviously I do not want a perfect replica! I require to produce something similar to the original manufacture.
Ormerod #007 (shaken but not stirred!)
Re: photogrammetry - how to get complete solid model
March 19, 2015 01:00PM
For something relatively simple such as a flange I would use my CAD program of choice, measure the original item and create a 'real' CAD model.
For more complex geometries I would probably try the scan and edit process that you are currently using.
Bob Morrison
Wörth am Rhein, Germany
"Luke, use the source!"
BLOG - PHOTOS - Thingiverse
March 19, 2015 01:31PM
Thanks Bob,
Agree totally and that is what I have done in DesignSpark Mechanical (which I will be using as a comparison), but for this exercise I would like to see what can be done in photogrammetry and associated tools.
So questions still remain how to fill the missing part/holes etc?
May 20, 2015 01:14AM
There's a video from 123DCatch that shows how to take your photos for good quality photogrammetry:
youtube - 123DCatch
It talks about 123DCatch, but I think the tips apply to photogrammetry in general. I've gotten some nice solid models following them. Though I haven't yet turned them into STLs. You can correct defects in the software.
One thing I don't think it mentions is that you want to use the highest fstop you can - at least 8. You need good depth of field, because the process uses details from the background as well as your subject.
A couple of my models:
Krishna
Buddha
June 01, 2015 09:29AM
I've spent around thirty hours to make this 3D model out of 28 photos.
Software I used are VisualSFM, Meshlab.
(https://youtu.be/V4iBb_j6k_g)
Suppose I can take many directional photos about an object with great resolution, creating a 3D model for 3D Printer or other application seem to depend on computing power.
I think I now have a mobile 3D scanner.
- DSLR camera with a tripod
- Post processing software
- Debian Linux workstation
For small object needs a flat surface and a camera provided decent PC that crunches image data.
Edited 1 time(s). Last edit at 06/01/2015 09:32AM by janpenguin.
