Interesting ideas. Some random comments in the text.
Mitchell Wrote:
> Has anyone looked at lower-cost fabricator
> concepts? Eg, there is an ULCPC notebook (or
> eventually a cell phone), USB dongle(s)
> controlling multiple fabricators, a couple of DC
> motors in each, and that's it. No other
> electronics. Replace electronics with software,
> fabbable mechanics, and simple wire circuits.
Could we power the motors over USB (in that case we'd probably need to keep the laptop plugged to the grid while printing)?
We'd also still need something capable of electrical input and output signals - an Arduino comes to mind (around 25 euros).
> Hand-waved examples:
> * Do shaft encoding with gears and spring
> switches, dumb DC motors, and software
> extrapolation between clicks.
Seems possible.
Also, end stops naturally with touch contacts instead of optoswitches.
> * Instead of shaft encoding, use a non-drive
> system to get precision position.
> ** A clockwork pendulum bounces between head and
> wall, several clicks per swing, providing velocity
> and position info. The computer provides
> high-precision timing for free. Software
> extrapolates between samples.
> ** Webcam/cell photo chips are cheap. One might
> be able to get high-precision position by image
> processing of a sheet-of-paper with a complex
> printed target.
This might get a bit tricky - webcam quality is not necessarily so good, lighting conditions and cast shadows change the picture, and the picture analysis programming might be heavy for a low performance laptop. I suspect it would also take a lot of programming effort, that could be put to better use. But in the long run this kind of high-information feedback loop would probably be good to have.
> ** Replace drive shafts with gears, and use
> software modeling of gear behavior and defects to
> recover accuracy.
Small errors could accumulate. Some kind of feedback will probably be needed.
> ** Replace a horizontal shaft with a rotating
> stage.
> * Simplify the z-axis.
> ** Float the stage or writer. Valve water in or
> out. Or simply drip it at a known rate, and use
> time as a proxy for position.
My gut feeling is that water would complicate things. But on the other hand, it could enable all kind of pneumatic fun.
> ** Human turns a screw.
Sounds like too much wasted time from the operator. That's what computers and machines are for, for tasks that require turning a screw every ten minutes.
> Any other ideas?
Could we replace the steelframe and fastenings with plastic too? If they have to be bought as new, they add up to some money too (maybe around 50 euro). Probably threaded rods and nuts are needed for the three axes at least, though.
> Basically, a bootstrap fab package would consist
> of a head, a dongle, some click-together fabbed
> structural pieces, a couple of cheap motors,
> wires, assorted fabbed mechanics, and some
> springs. That's it.
> Off topic:
> * Bone-like largely hollow structural pieces.
Sounds fun. I want to computer generate these with genetic algorithms
> * Adding microfibers to improve strength.
> Thank you for your inspiring work.
