Rep(St)rap design
Posted by sid
sid
Rep(St)rap design
June 25, 2008 02:25PM
I'm currently ordering some items to build my (yet very) own RepStrap.
The design itself is almost done, based on a 3cm thick chopping board made of PE I'm pretty sure it can also be done in ABS or PCL.
Now I'm wondering if that is a RepStrap (because it should build a complete RepRap) or is it a RepRap (becaus it can duplicate itself too) ?
Well, nevermind what it's called, tell me what you think:
Everything is designed for a simple buildup process, just a saw and a drill(press) and you're ready to go...
upper isometric view
and a look from below:
yeah I know, the z-axis is still missing and there are no lead screws,
also there will be some stiffening for the y-Axis.
If you need to know:
machine travel intended: 400 x 300 x 100 mm
interchangeable tools:
simple dremel (for making the pcbs)
and the v1.1 thermoplast extruder.
'sid
Re: Rep(St)rap design
June 25, 2008 02:36PM
Looks nice! How do you plan to handle the connection between your guide rails and your structural blocks?
sid
June 25, 2008 02:47PM
I got me some bush bearings (simple ptfe multilayer)
those will be pressfit; maybe glued, grub screwed to the structure.
fixed side will be grub screwed.
Or did I get you wrong?
'sid
Edited 2 time(s). Last edit at 06/25/2008 02:50PM by sid.
June 26, 2008 07:11AM
Looking good, are you planning to use the same system of belts as in darwin?
sid
June 26, 2008 08:21AM
for the x-Axis ? yes.
but only to synchronize the leadscrews.
But only to not have to mount a fourth stepper.
[Update]
Now, guide rails are approximately the correct length and z-Axis is present:
still without leadscrews and Motors and so forth.
Today I'm going to cut and drill my chopping board to pieces (hopefully)
I'll keep you updated
'sid
Edited 1 time(s). Last edit at 07/10/2008 08:15AM by sid.
sid
July 21, 2008 02:19PM
Nasty little bastard (chopping board) clogged my buzz-saw whilst cutting.
(one cut, ten minutes cleaning, another cut, another ten minutes... five times sad smiley)
just a small piece of squared rod as a guide firmly attached
and then the smaller cuts by hand
Nevertheless, it's cut into pieces finally
They wont win no beauty award, but they are good to go.
Next time I'll ask a pro winking smiley
Don't miss next week when there are black holes, ball bearings and bushings grinning smiley
Wish me luck
'sid
VDX
July 21, 2008 03:24PM
Hi sid,
... 20 years ago i built the cartesian mechanic of a laser-plotter out from white POM/Delrin - your black stuff looks cutted the same way, so i'ts maybe POM too.
When drilling holes, you need a very stable press-drill or the drill-holes wouldn't be exact aligned.
Another question: where are you located? - when in Germany (as your images imply), then maybe i can help you with some spare parts and a CNC-mill ...
Viktor
sid
July 21, 2008 06:34PM
Hi Viktor,
nope I was told it's PE500 (or 300, the vendor wasn't that sure about the molekular weight)
I made some test holes the other day and it cuts nicely.
But yes, I'll use a slightly oversized drillpress winking smiley
Was hat mich verraten, der K
VDX
July 22, 2008 03:42AM
Hi sid,
ok, then it's PE ...
Beside - i would prefer building with POM - excellent mechanical properties and optimal for milling ...
Viktor
PS: - jepp, die K
