Re: Anti-ooze nozzle August 24, 2008 09:48AM |
Re: Anti-ooze nozzle August 24, 2008 09:53AM |
Re: Anti-ooze nozzle August 24, 2008 10:31AM |
Admin Registered: 17 years ago Posts: 1,915 |
Re: Anti-ooze nozzle August 24, 2008 10:53AM |
Re: Anti-ooze nozzle August 24, 2008 12:51PM |
Re: Anti-ooze nozzle August 25, 2008 08:06AM |
Re: Anti-ooze nozzle August 25, 2008 11:06AM |
Re: Anti-ooze nozzle August 25, 2008 08:49PM |
Re: Anti-ooze nozzle August 25, 2008 11:47PM |
Re: Anti-ooze nozzle August 26, 2008 02:28AM |
Re: Anti-ooze nozzle August 26, 2008 02:59AM |
Re: Anti-ooze nozzle August 26, 2008 05:05AM |
Okay, drill a small hole for the shutoff valve and it leaks. So we drill a bigger one and it doesn't?
This seems like a lot of trouble and extra complexity to go to just to avoid having to peel off some fuzz off your print.
Re: Anti-ooze nozzle August 26, 2008 07:32AM |
Re: Anti-ooze nozzle September 06, 2008 08:35AM |
Re: Anti-ooze nozzle September 07, 2008 03:53AM |
Re: Anti-ooze nozzle September 07, 2008 04:20AM |
Re: Anti-ooze nozzle November 12, 2010 09:53AM |
Re: Anti-ooze nozzle November 12, 2010 08:32PM |
Re: Anti-ooze nozzle November 15, 2010 04:59AM |
Re: Anti-ooze nozzle November 15, 2010 05:32AM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Anti-ooze nozzle November 15, 2010 10:47AM |
Re: Anti-ooze nozzle November 15, 2010 12:19PM |
Re: Anti-ooze nozzle November 15, 2010 04:41PM |
Re: Anti-ooze nozzle November 16, 2010 08:14AM |
Re: Anti-ooze nozzle November 16, 2010 08:44AM |
martinprice2004
It would mean that you could produce a part scanning the head back and forth like an ink jet printer rather than a complex path like we have to use at the moment. This would be much faster than what we do now as the head moves less to produce a part. As an interim stage you could produce the outer surfaces following the perimeter as now to give a good non string finish and infill quickly using a scanning method.
Re: Anti-ooze nozzle November 16, 2010 09:49AM |
It completely cures it on my machines for both ABS and PLA.Quote
Reversing the motor does overcome stringing to some extent
Re: Anti-ooze nozzle November 16, 2010 09:56AM |
Re: Anti-ooze nozzle November 16, 2010 06:21PM |
Unless the object is a perfect rectangle you will do considerably more head movement than is currently done and the quality would suffer significantly.
Re: Anti-ooze nozzle November 17, 2010 02:51AM |
Re: Anti-ooze nozzle November 20, 2010 03:23AM |
