Endstop interrupt stop movements in any direction
Posted by myasaee
January 31, 2014 04:40PM
Hi
I have a K8200 3D printer which uses Marlin firmware and am modifying it for a project I'm doing.
I'm controlling the printer with the Marlin G codes using matlab and all is going great.
I've yet to find a way to stop all axis movements instantly. The M0 and M112 does not stop the movement immediately but only after previous movement is finished.
The endstop triggers work however, they only stop the movement in one direction only.
My question is, is there a way I can use an endstop trigger/interrupt to stop movements in both directions?
Thanks
Re: Endstop interrupt stop movements in any direction
February 01, 2014 02:52PM
I guess there isn't a way.
Anyways, an alternative solution I came up with was to only move the motors in 0.1mm increments in matlab. This way I can always check for a loadcell reading there so that when it exceeds, simply stop the movement.
VDX
February 01, 2014 05:36PM
... should it be an 'emergency break' with wrecking the actual print? - then you can implement a button to electrically deactivate all drivers ...
Viktor
