Alternatives to aluminum angle and channel in McWire? July 30, 2008 07:33PM |
Re: Alternatives to aluminum angle and channel in McWire? July 30, 2008 07:47PM |
Re: Alternatives to aluminum angle and channel in McWire? July 30, 2008 07:56PM |
Re: Alternatives to aluminum angle and channel in McWire? July 30, 2008 09:14PM |
Re: Alternatives to aluminum angle and channel in McWire? July 31, 2008 06:29PM |
Thckness Width Basic Cost # Strips Cost Per Strip Notes 1/8" 1/8" $5.13/ft 1 $5.13/ft Expensive, but already cut to the size we need. 1/8" 1/2" $3.46/ft 4 $0.865/ft Cheap, and only two strips from the center. 1/8" 1" $5.54/ft 8 $0.6925/ft Cheapest but strips from center might be uneven. 1/4" 1/4" $7.74/ft 2 $3.87/ft Higher price; thicker means a deeper channel. 1/4" 1/2" $6.93/ft 4 $1.7325/ft Cheaper but the center strips might be uneven.If we had 1/8"x1/4" strips, we could place them on the plywood and give it the same height as the aluminum channel, but they don't sell that size, so we would have to cut it ourselves either out of the 1/4"x1/4" or 1/4"x1/2". These of course are more expensive than the 1/8" thick, and I don't think it's worth the extra cost to make it the same height if we have to cut it anyway.
Description Qty plywood 1/2" x 3/4" x 13" 4 plywood 1/2" x 3/4" x 21" 2 PTFE 1/8" x 1/8" x 13" 8 PTFE 1/8" x 1/8" x 21" 4corresponding to the 4 13" lengths and 2 21" lengths of aluminum channel I'm replacing. The total length of 1/8" x 1/8" PTFE is 188", meaning I'll need 47" of the 1/8" x 1/2" PTFE bar (I'll buy 4 feet, giving me an extra inch to play with).
Re: Alternatives to aluminum angle and channel in McWire? July 31, 2008 07:06PM |
Admin Registered: 17 years ago Posts: 1,915 |
Re: Alternatives to aluminum angle and channel in McWire? July 31, 2008 07:10PM |
Re: Alternatives to aluminum angle and channel in McWire? July 31, 2008 07:20PM |
Re: Alternatives to aluminum angle and channel in McWire? July 31, 2008 07:49PM |
Re: Alternatives to aluminum angle and channel in McWire? July 31, 2008 08:00PM |
Re: Alternatives to aluminum angle and channel in McWire? July 31, 2008 09:04PM |
Re: Alternatives to aluminum angle and channel in McWire? July 31, 2008 09:10PM |
Re: Alternatives to aluminum angle and channel in McWire? August 01, 2008 03:52AM |
Admin Registered: 16 years ago Posts: 13,888 |
Re: Alternatives to aluminum angle and channel in McWire? August 02, 2008 12:21PM |
Re: Alternatives to aluminum angle and channel in McWire? August 02, 2008 01:27PM |
Re: Alternatives to aluminum angle and channel in McWire? August 02, 2008 11:58PM |
Re: Alternatives to aluminum angle and channel in McWire? August 03, 2008 04:00AM |
Re: Alternatives to aluminum angle and channel in McWire? August 03, 2008 11:36AM |
Re: Alternatives to aluminum angle and channel in McWire? August 03, 2008 02:36PM |
Re: Alternatives to aluminum angle and channel in McWire? August 03, 2008 04:53PM |
Re: Alternatives to aluminum angle and channel in McWire? August 03, 2008 06:11PM |
Re: Alternatives to aluminum angle and channel in McWire? August 03, 2008 07:21PM |
Re: Alternatives to aluminum angle and channel in McWire? August 03, 2008 11:42PM |
