Possible high-temp extruder barrel August 01, 2008 03:11PM |
Re: Possible high-temp extruder barrel August 01, 2008 04:57PM |
. ___to something like
. __ . | . _|with the extruder attached on the right and the carriage on the left (the periods are there to maintain spacing). As you're replacing the PTFE rod, you'd have to change the clamp anyway.
. I think this is the kind of thing you should experiment with yourself, trying different things like varied positions of the heatsink, varied lengths of the steel bolt, varied lengths of the heated barrel, etc.|
Re: Possible high-temp extruder barrel August 01, 2008 06:19PM |
Admin Registered: 19 years ago Posts: 1,915 |
Re: Possible high-temp extruder barrel August 01, 2008 07:33PM |
Admin Registered: 19 years ago Posts: 7,883 |
Re: Possible high-temp extruder barrel August 02, 2008 04:17AM |
Re: Possible high-temp extruder barrel August 02, 2008 06:54AM |
Re: Possible high-temp extruder barrel August 02, 2008 07:30AM |
Re: Possible high-temp extruder barrel August 02, 2008 12:07PM |
Re: Possible high-temp extruder barrel August 02, 2008 01:01PM |
Re: Possible high-temp extruder barrel August 02, 2008 03:42PM |
Admin Registered: 18 years ago Posts: 14,162 |
Re: Possible high-temp extruder barrel August 02, 2008 04:56PM |
Re: Possible high-temp extruder barrel August 03, 2008 11:58AM |
Re: Possible high-temp extruder barrel August 03, 2008 12:29PM |
Re: Possible high-temp extruder barrel August 03, 2008 01:44PM |
Re: Possible high-temp extruder barrel: Glass filled Teflon? August 05, 2008 08:38PM |
