Looking for 1.75mm nozzle with 1.85mm input diameter October 21, 2018 02:02PM |
Re: Looking for 1.75mm nozzle with 1.85mm input diameter October 21, 2018 04:00PM |
Re: Looking for 1.75mm nozzle with 1.85mm input diameter October 22, 2018 07:43AM |
Re: Looking for 1.75mm nozzle with 1.85mm input diameter October 22, 2018 08:10AM |
Re: Looking for 1.75mm nozzle with 1.85mm input diameter October 23, 2018 04:32AM |
Thanks for the tip. I assume 1.8mm in the nozzle should be OK, because filament will melt on contact. Indeed, I was not aware how small the airbrush nozzles are. The adapter would have to have an external M6 thread and an internal M1.7 thread.Quote
MKSA
I made a heatbreak drilled to 1.8mm instead of 2 but often experienced blocking due to retraction and gave up.
A M6 M1.75 adapter ?, you will need to make one. M1.7 taps break easily
Re: Looking for 1.75mm nozzle with 1.85mm input diameter October 23, 2018 06:55AM |
Re: Looking for 1.75mm nozzle with 1.85mm input diameter October 23, 2018 08:27AM |
