Triple stepper Z Axis October 08, 2016 07:18AM |
Re: Triple stepper Z Axis October 13, 2016 09:06AM |
Re: Triple stepper Z Axis October 13, 2016 03:04PM |
o5i
Hi i am buildn a ultimaker clone, but bigger...
Because of the bigger size i wanted to use 3 steppers on the z axis to avoid problems..
I thought if i use the 3 steppers it should be possible to auto calibrate the z axis using a proximity sensor..
I saw there is a options called auto leveling..
o5i
What proximity sensor to use? capacitive, inductive or ultrasonic - analog or digital?
deckingman
The biggest problem with multiple steppers on the Z axis is keeping them in sync because when you first power up the machine, they will all jump to the nearest whole step. Some will jump forwards and some will jump backwards so after a number of power cycles, the problem will be exacerbated. For info, my bed weighs around 7Kg and is lifted using 3 screws but with a continuous belt and a single Nema 17 motor with 1:1 gearing.
Re: Triple stepper Z Axis December 20, 2016 11:43PM |
Re: Triple stepper Z Axis December 21, 2016 03:18AM |
Re: Triple stepper Z Axis June 30, 2017 06:14AM |
Re: Triple stepper Z Axis June 30, 2017 05:57PM |
Re: Triple stepper Z Axis June 30, 2017 06:58PM |
Re: Triple stepper Z Axis July 01, 2017 02:38AM |
Re: Triple stepper Z Axis July 11, 2017 12:16PM |
Re: Triple stepper Z Axis July 12, 2017 05:10AM |
Re: Triple stepper Z Axis April 14, 2019 11:09AM |
Re: Triple stepper Z Axis April 14, 2019 12:54PM |
