Laser Cut Parts (Bits from Bytes) August 09, 2008 07:41AM |
Re: Laser Cut Parts (Bits from Bytes) August 11, 2008 11:12AM |
Re: Laser Cut Parts (Bits from Bytes) August 14, 2008 10:33PM |
Re: Laser Cut Parts (Bits from Bytes) August 15, 2008 08:09AM |
Re: Laser Cut Parts (Bits from Bytes) August 15, 2008 12:15PM |
Re: Laser Cut Parts (Bits from Bytes) August 17, 2008 01:41PM |
Re: Laser Cut Parts (Bits from Bytes) August 17, 2008 10:01PM |
Re: Laser Cut Parts (Bits from Bytes) August 18, 2008 06:53AM |
Re: Laser Cut Parts (Bits from Bytes) August 18, 2008 03:45PM |
Re: Laser Cut Parts (Bits from Bytes) August 19, 2008 01:42PM |
Re: Laser Cut Parts (Bits from Bytes) August 19, 2008 07:04PM |
Re: Laser Cut Parts (Bits from Bytes) August 20, 2008 08:41AM |
Re: Laser Cut Parts (Bits from Bytes) September 01, 2008 05:21PM |
Re: Laser Cut Parts (Bits from Bytes) September 02, 2008 05:49AM |
Re: Laser Cut Parts (Bits from Bytes) September 02, 2008 07:15AM |
Re: Laser Cut Parts (Bits from Bytes) September 02, 2008 07:21PM |
Re: Laser Cut Parts (Bits from Bytes) September 03, 2008 03:22AM |
Re: Laser Cut Parts (Bits from Bytes) September 03, 2008 04:51AM |
Re: Laser Cut Parts (Bits from Bytes) September 03, 2008 09:08AM |
Re: Laser Cut Parts (Bits from Bytes) September 07, 2008 05:56AM |
----------------- <- rod
----------- <- Part 42
The diagram is quite exaggerated but they were out of line by enough that sliding the assembly with and with out 42 attached had a noticeable change in friction. I filed the ends to 90 Deg and it now slide's as easily attached to 42 as on it's own.|
Re: Laser Cut Parts (Bits from Bytes) September 08, 2008 05:36AM |
Re: Laser Cut Parts (Bits from Bytes) September 09, 2008 06:12AM |
Re: Laser Cut Parts (Bits from Bytes) September 09, 2008 06:41AM |
Admin Registered: 18 years ago Posts: 14,162 |
Re: Laser Cut Parts (Bits from Bytes) September 09, 2008 03:14PM |
Re: Laser Cut Parts (Bits from Bytes) September 09, 2008 11:03PM |
Re: Laser Cut Parts (Bits from Bytes) September 10, 2008 01:06PM |
Re: Laser Cut Parts (Bits from Bytes) September 11, 2008 08:25AM |
Re: Laser Cut Parts (Bits from Bytes) September 12, 2008 07:21AM |
Re: Laser Cut Parts (Bits from Bytes) September 13, 2008 11:43PM |
Re: Laser Cut Parts (Bits from Bytes) September 14, 2008 01:57PM |
or has that been thought of??!
