Finished cartesian bot using bike chain August 25, 2008 06:41PM |
Re: Finished cartesian bot using bike chain August 26, 2008 12:43PM |
Re: Finished cartesian bot using bike chain August 26, 2008 02:46PM |
Re: Finished cartesian bot using bike chain August 26, 2008 03:52PM |
Re: Finished cartesian bot using bike chain August 27, 2008 03:47AM |
Re: Finished cartesian bot using bike chain August 27, 2008 04:37AM |
Admin Registered: 16 years ago Posts: 13,888 |
Re: Finished cartesian bot using bike chain August 27, 2008 05:01AM |
I seem to remember having a K'NEX toy with similarly shaped plastic chain link
possibly cast them out of metal in the future, maybe tin or one of the low melting point solder alloys
Re: Finished cartesian bot using bike chain August 27, 2008 07:21AM |
Re: Finished cartesian bot using bike chain August 27, 2008 07:29AM |
Re: Finished cartesian bot using bike chain August 27, 2008 07:52AM |
Well I was imagining a modified design which requires no overhangs (or limit it to overhangs which could be created by gap-spanning as Nophead has displayed)
As to the bit about removing support struts from a hundred little chain links, I did suggest casting them
If you cast a few of em, you can use those to make a tree mold
Re: Finished cartesian bot using bike chain August 27, 2008 08:25AM |
Re: Finished cartesian bot using bike chain August 27, 2008 09:01AM |
I think we can design a time-efficient process, though. Don't forget that casting is used for mass manufacturing.
Well, if you design it just right, cutting a part away from the tree could be as quick and simple as making one snip with scizzors/wire cutters/whatnot
Re: Finished cartesian bot using bike chain August 27, 2008 12:01PM |
Re: Finished cartesian bot using bike chain August 27, 2008 07:10PM |
