Reducing weight on Cartesian printer X and Y axis January 19, 2022 04:07PM |
Re: Reducing weight on Cartesian printer X and Y axis January 19, 2022 04:33PM |
Admin Registered: 16 years ago Posts: 13,888 |
Re: Reducing weight on Cartesian printer X and Y axis January 19, 2022 06:50PM |
Re: Reducing weight on Cartesian printer X and Y axis January 19, 2022 11:29PM |
Re: Reducing weight on Cartesian printer X and Y axis January 20, 2022 01:19AM |
the_digital_dentist
You could make a printer with interchangeable beds of different sizes and use the bed that is just large enough to accommodate each print.
You can print on a sacrificial foam bed without a heater or metal plate.
If you were really concerned about ringing, you'd just print slowly. "Ringing" is a euphemism for printing fast. You're not really concerned about ringing. You really want to print fast, but ringing is spoiling your high speed prints.
If you want to print fast and avoid ringing, the best thing to do is reduce the moving mass and make everything as rigid as possible. That's why people build printers that don't attempt to throw a massive bed around at print speed.
It isn't hard to build a relatively light mechanism that can move fast. The real problem is and always has been building an extruder that can keep up with the rest of the motion. You also need a print cooler that can keep up with high speed printing because what's the point of printing at 500 mm/sec if the prints look like crap because the printer keeps squirting hot plastic on top of still hot plastic?
Resin printers only move slowly in one direction and don't have problems with ringing. You have a narrower selection of material to print with, and print size is usually limited by the cost of the resin, but if you use a bowden type extruder on an FDM printer you give up the ability to print flexible materials. So any way you go there are trade-offs.
If you want to eliminate ringing from prints and you don't want to spend a fortune, print slower. You can still print with all the same materials. Print quality can be high (you might have to do some extruder tuning, but you'll have to do a lot of that if you try to print very fast).
Speed is over-rated. People can see print quality or lack of print quality, but they can't see how long it took.
Re: Reducing weight on Cartesian printer X and Y axis January 20, 2022 01:42AM |
Re: Reducing weight on Cartesian printer X and Y axis January 20, 2022 03:44AM |
VDX
... for "moving bed in XYZ" -- I've seen several samples and machines with this setup - one was a delta CNC-milling setup, the other a "ultrasonic speed metal-jetter" with an industrial robot-arm moving a metal plate as "target" above the jetter to impact-sinter the part onto it
Re: Reducing weight on Cartesian printer X and Y axis January 20, 2022 04:05AM |
valsk
VDX
That's pretty crazy, particularly the last one.
Re: Reducing weight on Cartesian printer X and Y axis January 30, 2022 11:00AM |
Re: Reducing weight on Cartesian printer X and Y axis February 23, 2022 02:14PM |
