Why are there Nichrome wire ends sticking out of the extruder barrel? September 06, 2008 07:49AM |
Re: Why are there Nichrome wire ends sticking out of the extruder barrel? September 06, 2008 09:23AM |
It doesn't make sense to me to have 40mm (two 20mm lengths on each side) of the heater wire heating the air instead of the barrel
the solder might melt
if you apply the JB-Weld around the thing and let it set
Re: Why are there Nichrome wire ends sticking out of the extruder barrel? September 06, 2008 10:02AM |
Re: Why are there Nichrome wire ends sticking out of the extruder barrel? September 06, 2008 10:14AM |
Admin Registered: 17 years ago Posts: 1,915 |
Re: Why are there Nichrome wire ends sticking out of the extruder barrel? September 06, 2008 10:29AM |
Re: Why are there Nichrome wire ends sticking out of the extruder barrel? September 06, 2008 10:34AM |
Re: Why are there Nichrome wire ends sticking out of the extruder barrel? September 06, 2008 10:58AM |
Re: Why are there Nichrome wire ends sticking out of the extruder barrel? September 06, 2008 11:15AM |
Re: Why are there Nichrome wire ends sticking out of the extruder barrel? September 06, 2008 11:25AM |
So... why use a thermal insulator between the nichrome and the barrel?
Re: Why are there Nichrome wire ends sticking out of the extruder barrel? September 06, 2008 11:44AM |
Re: Why are there Nichrome wire ends sticking out of the extruder barrel? September 06, 2008 11:59AM |
Re: Why are there Nichrome wire ends sticking out of the extruder barrel? September 06, 2008 12:31PM |
Re: Why are there Nichrome wire ends sticking out of the extruder barrel? September 06, 2008 12:45PM |
Re: Why are there Nichrome wire ends sticking out of the extruder barrel? September 06, 2008 05:02PM |
Re: Why are there Nichrome wire ends sticking out of the extruder barrel? September 06, 2008 10:29PM |
Re: Why are there Nichrome wire ends sticking out of the extruder barrel? September 07, 2008 03:43AM |
Re: Why are there Nichrome wire ends sticking out of the extruder barrel? September 07, 2008 04:09AM |
Re: Why are there Nichrome wire ends sticking out of the extruder barrel? September 07, 2008 05:40AM |
I think I can wrap the wire around the nichrome, put a blob of solder to form an electrical connection
I think with my method it could be cheaper than cerastil and more efficient than any of the current options.
Re: Why are there Nichrome wire ends sticking out of the extruder barrel? September 17, 2008 12:27AM |
Feasibility of Anodizing under the nichrome wire? September 17, 2008 01:27PM |
Alternative Elect. Insulator/Thermal *conductor* under Nichrome, Mica. September 17, 2008 01:52PM |
Re: Why are there Nichrome wire ends sticking out of the extruder barrel? September 17, 2008 02:35PM |
Admin Registered: 16 years ago Posts: 13,888 |
bob657
Re: Why are there Nichrome wire ends sticking out of the extruder barrel? April 24, 2010 09:39PM |
