Different steps/mm between X and Y November 20, 2012 08:36PM |
Re: Different steps/mm between X and Y November 20, 2012 11:56PM |
Re: Different steps/mm between X and Y November 21, 2012 12:35AM |
Re: Different steps/mm between X and Y November 21, 2012 08:28AM |
You should really calculate steps/mm instead of measuring it
No loose belt, no loose grub screws,not missing a step in a 20hr print, low backlash at .03 on X, and .09 on Y.
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Different steps/mm between X and Y November 21, 2012 11:55AM |
Admin Registered: 19 years ago Posts: 7,883 |
For example, one thing not precisely known is the diameter of the pulley. Sure, it's made to match the pitch of the belt, but at which radius precisely? Can't be said until you actually measure the resulting belt movement.
Re: Different steps/mm between X and Y November 21, 2012 11:56AM |
Re: Different steps/mm between X and Y November 21, 2012 12:34PM |
Re: Different steps/mm between X and Y November 21, 2012 02:27PM |
Re: Different steps/mm between X and Y November 22, 2012 06:50AM |
Re: Different steps/mm between X and Y November 22, 2012 07:22AM |
Re: Different steps/mm between X and Y November 22, 2012 11:14AM |
Re: Different steps/mm between X and Y November 27, 2012 07:28AM |
Re: Different steps/mm between X and Y November 27, 2012 11:45AM |
Re: Different steps/mm between X and Y November 27, 2012 02:21PM |
Belt tension does not affect steps, only backlash/slop. The belts could be a mile long, the diameter of the drive gear is a constant. With equal stepps I get mechnical dimensional accuracy, but not when printing.
Re: Different steps/mm between X and Y November 27, 2012 06:25PM |
Re: Different steps/mm between X and Y November 27, 2012 07:46PM |
Can you show me some math on that? By that figuring, a 5 mm diameter gear, if the belt is tight enough, in one revolution is going to move as far as a 10 mm diameter gear with a loose belt. That doesn't figure. My belts are equally tensioned anyway.
So what about a toothless belt on a grooved pully? The diameter of the pully directly determines the distance of travel in one revolution.
Re: Different steps/mm between X and Y August 11, 2013 03:53PM |
Re: Different steps/mm between X and Y August 11, 2013 11:18PM |
