Z axis changing direction DURING print????
February 05, 2013 11:38PM
I have had my Mendel working successfully for a few months now and just today I had two prints ruined because the z axis started moving down during the print instead of up! I have never had this problem before and I can't find any discussions online about it. After I paused the print with printerface, I tried moving the z axis again and the z axis moved up just like normal again. Any ideas??
I'm running RAMPS 1.4, sprinter, and slic3r 0.9.7. Also, my pololu drivers are being cooled so I don't think it is over heating. I checked out my gcode in a gcode viewer and it appears to be fine so maybe its a mechanical issue? Has anyone ever heard of that happening or know what would be causing it?
Re: Z axis changing direction DURING print????
February 06, 2013 01:01AM
Electrical noise from some nearby source?
February 06, 2013 10:21AM
Really? Could that do it? My printer is in the same spot it has been for the past few months and it's never done that before, so I don't know where new electrical noise would be coming from...
February 06, 2013 05:06PM
Poor connection on the direction pin for the Z axis pololu?
Can you swap the drivers over or are they soldered in?
February 06, 2013 07:02PM
My pololus are swap-able. I will try that out and see if it makes a difference.
February 07, 2013 08:15PM
When I tried swapping my pololus, I found some wires to my z motor that had a bad connection and must have been shaken loose from the vibration of the printer. All is well now. Thanks for the suggestions.
