Re: New light extruder concept out of bolt February 02, 2014 02:16PM |
Re: New light extruder concept out of bolt February 02, 2014 03:46PM |
Re: New light extruder concept out of bolt February 02, 2014 06:13PM |
Re: New light extruder concept out of bolt February 03, 2014 05:42AM |
Re: New light extruder concept out of bolt February 03, 2014 06:54AM |
Re: New light extruder concept out of bolt February 03, 2014 07:46AM |
A2
Congrats
I love the looks of it.
I would like to see a line drawn on the filament with a fine permanent marker, zoom up close and post a vid.
It will be interesting to see if it can feed 100's of feet of filament without twisting.
Have you thought about how to swap out the inverted-worm to switch to a different filament diameter?
Print herringbone bevel gears, might help with the backlash.
With a high extruder force you might be able to use a smaller stepper motor NEMA 14, or how about a NEMA 8
Re: New light extruder concept out of bolt February 03, 2014 09:56AM |
Chri
Hmm, interressting concept, but i can`t see the real benefits of this type compared to a "normal" geared extruder ?
a Printer with a geared extruder can also make 500m/s (movement), and most ABS/PLA isn`t even good enough to print with this speed.
pro: alot of force, but is so much really necessary?
con`s:
-slow acceleration -> slow retract
-large design (bulky) , even with built with a nema 14 (nema 8 is not much lighter than nema14)
-changing filament would take very long ?
- if the filament diameter is changing too much it may slip or stuck ?
Chri
Re: New light extruder concept out of bolt February 03, 2014 10:45AM |
Chri
con`s:
Chri
Re: New light extruder concept out of bolt February 03, 2014 11:07AM |
Re: New light extruder concept out of bolt February 03, 2014 11:39AM |
Re: New light extruder concept out of bolt February 03, 2014 02:42PM |
Re: New light extruder concept out of bolt February 03, 2014 03:57PM |
nicholas.seward
Usually if I have a problem printing it is a filament issue. Geared pushers are great until you strip the filament or it gets kinked after the hobbed pulley. For me this has the potential to provide a great amount of force, reduce the filament deformation (nice for bowdens), and support the filament all the way to the extruder.
This is a great first stab. It is probably unfair at this point to compare it to refined existing designs. (My side rant for today is that we would all be driving cars with Wankel engines if they would have been invented first.) The acceleration and size of the design can be morphed greatly with different design choices. (I feel like I could make this more compact and faster with standard spur gears and just require the nuts to be pressed into nut traps instead of soldered on tubes.) The filament diameter variance will have to be tested.
Yes this design is capable of two gears, the second gear is very high, so it may work great with a "direct" driven first geard nema14 as wellQuote
This design is essentially a gear reduced driver, like the Wade's extruder. Instead of using gears to multiply the torque produced by the motor, I use a nut that has the same effect. My green gears are the first gear and you can view the nut as the second gear (or is the filament the second gear?). For every rotation of the first gear the filament is only moved about 0.8mm.
You have some good points. My experience with direct drive 1.75mm extruders is that when the hot-end jams, the drive gear chews a divot into the filament and then it can no longer push. When the hot-end clogs I find that I can usually manually push on the filament and get the plastic to start flowing again.
the "kinked" problem after the bolt is because most of the printed extruder designs have just a too large gap between the bolt and the filamentguide.Quote
Re: New light extruder concept out of bolt February 04, 2014 08:02AM |
Re: New light extruder concept out of bolt February 11, 2014 07:59PM |
Re: New light extruder concept out of bolt February 12, 2014 02:52AM |
Re: New light extruder concept out of bolt February 12, 2014 11:48AM |
Re: New light extruder concept out of bolt February 12, 2014 02:38PM |
Re: New light extruder concept out of bolt February 12, 2014 03:12PM |
Re: New light extruder concept out of bolt February 13, 2014 12:50AM |
Re: New light extruder concept out of bolt February 13, 2014 11:02AM |
Re: New light extruder concept out of bolt February 13, 2014 02:48PM |
Re: New light extruder concept out of bolt February 23, 2014 09:01AM |
Re: New light extruder concept out of bolt February 23, 2014 09:11PM |
Re: New light extruder concept out of bolt February 24, 2014 12:30AM |
Re: New light extruder concept out of bolt February 24, 2014 08:05AM |
Re: New light extruder concept out of bolt February 25, 2014 07:56AM |
Re: New light extruder concept out of bolt February 25, 2014 09:53AM |
Re: New light extruder concept out of bolt February 28, 2014 02:21PM |
Now called SnakeBite extruder March 01, 2014 03:04PM |
Re: Now called SnakeBite extruder March 01, 2014 07:13PM |
