The Remoter November 08, 2013 07:34PM |
Re: The Remoter November 09, 2013 02:07AM |
Re: The Remoter November 10, 2013 10:55AM |
Re: The Remoter November 10, 2013 12:48PM |
| FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
| Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: The Remoter November 11, 2013 09:58AM |
Re: The Remoter November 11, 2013 11:15AM |
Re: The Remoter November 11, 2013 12:16PM |
Guizmo
@Sublime,
Thanks for the tip. I wonder how that system works. It appears it is a multiturn system, so it can work with the window crank. If that's true, then that's a much better mechanism, making possible UNLIMITED power transmision, not only a restricted amount.
That makes me think, we could design an extruder almost as light as a Bowden extruder, with a remote motor but with no oozing, as the pulling mechanism could be just above the hot end, just like normal extruders! With my design that's not possible!
Re: The Remoter November 11, 2013 12:46PM |
Guizmo
@Sublime,
Re: The Remoter November 11, 2013 01:09PM |
Re: The Remoter November 11, 2013 01:31PM |
Sublime
Yes it is multiturn. I used to install them and I believe they may have been some kind of syncro cable like ddseeker linked to or it was a ball chain. The ball chain would be easy enough to test out in a printed version and may be worth a try.
Re: The Remoter November 11, 2013 01:38PM |
Re: The Remoter November 11, 2013 02:15PM |
Re: The Remoter November 11, 2013 02:20PM |
Re: The Remoter November 11, 2013 04:17PM |
Re: The Remoter November 11, 2013 05:11PM |
Guizmo
@ddseeker: I also tried to find the patent for the Spal system with no success.
Re: The Remoter November 11, 2013 06:18PM |
Anyway, it's good to learn and improve existing technology. Let's make it better!|
Re: The Remoter November 11, 2013 07:11PM |
Re: The Remoter November 11, 2013 08:45PM |
Re: The Remoter November 12, 2013 10:04AM |
Re: The Remoter November 12, 2013 01:50PM |
http://en.m.wikipedia.org/wiki/Patent
a patent provides the right to exclude others[17] from making, using, selling, offering for sale, or importing the patented invention for the term of the patent, which is usually 20 years from the filing date[4] subject to the payment of maintenance fees
Re: The Remoter November 12, 2013 02:05PM |
Re: The Remoter November 12, 2013 04:31PM |
Re: The Remoter November 12, 2013 05:16PM |
Re: The Remoter November 12, 2013 05:25PM |
Re: The Remoter November 12, 2013 05:30PM |
Re: The Remoter November 12, 2013 07:22PM |
Re: The Remoter November 12, 2013 09:46PM |
Admin Registered: 16 years ago Posts: 730 |
Re: The Remoter November 13, 2013 09:43AM |
Re: The Remoter November 13, 2013 01:23PM |
Re: The Remoter November 13, 2013 01:24PM |
