Z axis with 1 stepper motor over belt December 18, 2013 02:15PM |
Re: Z axis with 1 stepper motor over belt December 18, 2013 09:13PM |
Re: Z axis with 1 stepper motor over belt December 19, 2013 08:50AM |
However, I think you might also consider a belt driven Z axis.
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Z axis with 1 stepper motor over belt December 19, 2013 10:35AM |
Re: Z axis with 1 stepper motor over belt December 19, 2013 10:40AM |
bensch
Has anyone tried this?
Have you ever looked at the orginal (Sells) Mendel?|
Re: Z axis with 1 stepper motor over belt December 19, 2013 11:48AM |
Traumflug
... and say good bye to any kind of layer thickness precision. Having something solid on the Z axis has a reason: this gear must withstand the acceleration forces of the print head which happen in vertical direction, too.
| FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
| Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Z axis with 1 stepper motor over belt December 27, 2013 10:30AM |
Re: Z axis with 1 stepper motor over belt January 26, 2014 09:48AM |
