Skate Bearings?
October 03, 2009 01:15AM
Question about size. Since skate bearings seem to be becoming a universal component for all things RepRap rleated...
Are skate bearings standardized to a single size? And are skateboard bearings internchangeable with skate bearings?
Re: Skate Bearings?
October 03, 2009 06:27PM
I happened to find this, after wondering what sizes of bearings are used on Mendel.
[www.vxb.com]
Mendel I think uses, 608, 625 and 624, at least that is what I can gather from the file names in SVN
Re: Skate Bearings?
October 03, 2009 11:17PM
I'm looking through that web sites description of different products, and whether its skate or skateboard bearings, the dimensions seem to be coming up as 8x22x7. (inner diameter x outer diameter x "B" which must stand for thickness)
So if there is any real difference between skate and skateboard bearings, it must be a difference in the kind of stresses that they are designed to withstand.
Either type of bearing should be able to withstand a person standing or jumping in it while it rolls for miles in possibly dusty souroundings, which is probably more stress than it's going to get in RepRap related applications. I'll probably just go with what's cheap.
Re: Skate Bearings?
October 04, 2009 01:53PM
I have bought both skate and skateboard bearings they were identical bearings.
They all have the standard 8x22x7 dimensions.
Skates/ Roler blades use two bearings per wheel.
I have not looked at a skate board I would expect them to be identical as in Two bearings per wheel.
Bodge It [reprap.org]
BIQ Sanguinololu SD LCD board BIQ Stepcon BIQ Opto Endstop
BIQ Heater Block PCB BIQ Extruder Peek clamp replacement BIQ Huxley Seedling
BIQ Sanguinololu mounting BIQ standalone Sanguinololu or Ramps mounting Print It Stick It Cut it
My rep strap: [repstrapbertha.blogspot.com]
Buy the bits from B&Q pipestrap [diyrepstrap.blogspot.com]
How to Build a Darwin without any Rep Rap Parts [repstrapdarwin.blogspot.com]
Web Site [www.takeaway3dtech.com]
Re: Skate Bearings?
October 05, 2009 12:47PM
As a test I just did a google search for "8x22x7". It looks like this size is also being sold as "model car bearings" and "hobby motor bearing". I found an outfit that will sell them for 58 cents each (U.S. funds) which is cheaper than what I've seen on skate supplier web sites. I'm betting that they will generally be cheaper through non-skate related suppliers.
Re: Skate Bearings?
October 05, 2009 02:30PM
Check around on ebay. I bought a lot of 32 for $10. It was more bearings than I needed, but I couldn't beat that price. And those extra bearings wound up in other projects.
