Direct Pinch Print Quality Question December 20, 2013 10:20PM |
Re: Direct Pinch Print Quality Question January 02, 2014 05:34PM |
Nudel
Have you checked the tension on the extruder idler, and cleaned the teeth of the filament driver (hobbed bolt/gear, depending on your machine)?
If the teeth are partly clogged (due to too high or too low idler tension) it can slip at the same place, producing a pattern that repeats like that.
Re: Direct Pinch Print Quality Question January 04, 2014 12:29AM |
Re: Direct Pinch Print Quality Question January 06, 2014 12:34AM |
