source for T-Nuts
December 29, 2013 05:15AM
Hi
Does anyone have a good UK source for the M4 slot6 T-Nuts as used with extrusion with 6mm slots eg. Ormerod.
Rory
Re: source for T-Nuts
January 01, 2014 10:11PM
Rory166
Hi
Rory
If you didn't find any yet try [www.aluminium-profile.co.uk]
What is Open Source?
What is Open Source Hardware?
Open Source in a nutshell: the Four Freedoms
CC BY-NC is not an Open Source license
January 11, 2014 09:17AM
January 11, 2014 12:56PM
Thanks
I just think 50p per nut is outrageous. So far it looks like I will have to buy from the US or France. The French option looks good at 0.18 Euro each but the website is only in french so I am a little hesitant. At least no customs duty from France. Why no-one in the UK seems to sell these at a proper price I do not know.
Rory
January 11, 2014 03:04PM
January 12, 2014 02:57PM
Try looking for Metric Tab Weld Nuts. They are usually much cheaper but only load from the end. I've used thousands of them in 40mm extrusions.
January 12, 2014 03:34PM
The cheapest on Misumi France is 0.33€ (taxless) each for less than 500nuts !
January 12, 2014 05:49PM
I must be stupid, I can't even figure out how to use the Misumi web site!
Not much luck searching for weld nuts either.
January 26, 2014 12:26AM
@bobc You're not alone. I've had trouble figuring out that crazy website too.
I don't know if anyone else has tried this but I have successfully used 1/4" carriage bolts in 1" aluminum t-slot extrusion. The head of the bolt fits almost perfectly in the slot. Some of them require a tiny grind to fit. It is pretty easy and cheap as well. I have used the nuts in my clone of mendelmax 2.
March 27, 2014 06:51PM
With some tweaking, this might work.
April 20, 2014 05:15PM
I use m5 nuts in 20x20mm t-slot (5 or 6mm gap, I'm not sure) they work perfectly, but must be inserted from the ends.
September 16, 2014 06:13PM
Bought mine from here
[stores.ebay.co.uk]
December 23, 2014 12:06PM
I get mine from RS.
Z
December 27, 2014 06:53AM
What Konwiddak said-
An M5 full nut will slip quite snugly down the channel of 20X20 Bosch Rexroth 6mm slot
An M5 nut with a couple of flats filed/ ground will slip down V slots 5mm slot.
I sound like a cheapskate but it's surprising how many nuts you end up using.
BoschRexroth fittings - angle brackets etc. - come with M4 fixings but will take an M5 without modifying.
-a
January 08, 2015 05:26PM
Mr alan richard
Your idea is....a great example of KISS.
The filed M5 is not as robust and easy to install as a regular T-nut but it's...dirt cheap.
And, I would say, better and easier to manufacture than a printed T-nut with a M3 nut insert.
thanks a lot
January 12, 2015 04:16AM
you can always get from china... if you plan in advance
I've ordered from M5 here before, seems fine.
Did the job and cheap as!
M4 here
Edited 1 time(s). Last edit at 01/12/2015 04:22AM by Dust.
January 24, 2015 03:28AM
However, since China is 30 days away and when I need 10 more t-nuts I'm not that calm,
IMPORTANT ADDITION: If the filed flats are a little big bigger, you can insert the M5 just anywhere in the channel, not neccessary at the ends.
And this is a HUGE advantage, especially since I have my printer allready assembled.
So, till T-nuts arrive, filed M5 work just fine !!!
More savings :-)
