simplest comercial machine
Posted by VDX
VDX
October 19, 2009 08:08AM
Hi all,
look into the documentation of a comercial paste-dispensing 3D-roboter: [www.globaco.de]
It's an extreme simple setup but has a price of 5000 Euros eye popping smiley
Anyway ... it's much lower parts count, than any other actual system spinning smiley sticking its tongue out
Viktor
Re: simplest comercial machine
October 19, 2009 08:33AM
English version:
English Version
Edited 1 time(s). Last edit at 10/19/2009 08:34AM by annodomini2.
October 19, 2009 01:12PM
Looks like a commercial version of the McWire setup.
VDX
October 19, 2009 03:10PM
... and this is the point >grinning smiley<
October 20, 2009 12:22AM
Ehmmm... 300 mm/sec. This is, like, 50 times the speed of a McWire?
-Geert
VDX
October 20, 2009 03:28AM
... this seems to be really fast - maybe wrong?
My (max. 10kHz) microstepping drivers manage 50mm/s with halfstep@4kHz (errors when faster eye rolling smiley) on a 5mm/rev spindle ... then 31.25mm/s with 1/8 microstepping@10kHz and even slower when higher microstepping (but with higher accuracy spinning smiley sticking its tongue out)
Next tim i'll receive some 200kHz- 1/50-microstepping drivers with corresponding motors - then i'll estimate nearly 125mm/s@50kHz with 1/10 microstepping and 100mm/s@200kHz with 1/50-microstepping.
Never above 200mm/s in a 'real' setup - 300mm/s will be 18m/min, what's really, REALLY fast for a stepper driven CNC-robot eye popping smiley
Either it's simply an calculated error or measured without any load or such confused smiley
October 20, 2009 04:38AM
It is belt drive with a 0.1mm step size, so those speeds are easily achievable.
VDX
October 20, 2009 05:21AM
... with so big steps it's a problem with speed and resonancy-errors eye popping smiley
My CNC-mill has 0.025mm at fullstep and then max. 2000Hz without load, so a max. speed of 50mm/s ... with halfstepping i can go until 6kHz freerun, so max. 75mm/s, but sometimes with stepping errors too eye rolling smiley
I have direct-coupled motors, the Mario robot toothbelts, what's more damping, so maybe some more speed too, but for what confused smiley
Viktor
