Gear dimensions, please? February 19, 2014 06:45PM |
Re: Gear dimensions, please? February 20, 2014 04:11PM |
Admin Registered: 13 years ago Posts: 730 |
Line 68: gear_separation=7.4444+32.0111+0.25;that would be 39.7055 millimeters, for those of you who don't have a calculator handy.
Line 289: import_stl("large_gear.stl"); Line 333: import_stl("small_gear.stl");OK, cool. Now we can see gears when we compile, and they actually move when we change gear_separation! If we uncomment line 30 we can see where the idler goes:
Line 29: //Place for assembly. Line 30: wadeidler();
Line 62: layer_height=0.4;
gear (number_of_teeth=43, circular_pitch=268, gear_thickness =gear_thickness, rim_thickness = 7, rim_width = 3, hub_thickness = nut_trap_thickness+nut_trap_depth, hub_diameter = 22, bore_diameter = 8, circles=0);
gear (number_of_teeth=10, circular_pitch=268, gear_thickness = 9, rim_thickness = 9, hub_thickness = 18, hub_diameter = 18, bore_diameter = 5.25, circles=0);
Re: Gear dimensions, please? February 20, 2014 08:02PM |
