Mendel aluminum bar instead of steel bar
Posted by rhmorrison
December 22, 2009 05:41AM
I haven't been able to find any A2 or BMZ bar.
Would it be possible to use aluminum bar instead or is it not strong enough?
Re: Mendel aluminum bar instead of steel bar
December 22, 2009 07:02AM
I think it will sag under the weight. Where are you, steel rods should be available in most countries?
December 22, 2009 07:53AM
I'm in Germany (near Karlsurhe).
I have only found the normal steel bar (i.e. RUSTS).
BMZ or A2 bar I haven't found yet.
The normal hardware store chains here are BAUHAUS and HORNBACH und neither carry A2 steel bar.
And the aluminum bar is very pretty, but I assumed that it probably isn't stiff enough for it's purpose in the Mendel.
December 22, 2009 08:45AM
Yes A2 would be difficult to find in a hardware store in the UK but very easy to get mail order from places like RS, and Farnell.
December 22, 2009 10:22PM
I am using normal steel bar that hasnt so far rusted.
I also I know I dont have rusty fingers.
Some people do have rusty fingers any thing they touch rusts.
Bodge It [reprap.org]
BIQ Sanguinololu SD LCD board BIQ Stepcon BIQ Opto Endstop
BIQ Heater Block PCB BIQ Extruder Peek clamp replacement BIQ Huxley Seedling
BIQ Sanguinololu mounting BIQ standalone Sanguinololu or Ramps mounting Print It Stick It Cut it
My rep strap: [repstrapbertha.blogspot.com]
Buy the bits from B&Q pipestrap [diyrepstrap.blogspot.com]
How to Build a Darwin without any Rep Rap Parts [repstrapdarwin.blogspot.com]
Web Site [www.takeaway3dtech.com]
December 23, 2009 03:04AM
BodgeIt Wrote:
> I am using normal steel bar that hasn't so far
> rusted.
> touch rusts.
Unfortunately the brand new bar in the hardware stores I visited has already started to rust which is why I definitely want A2 steel bar!
December 23, 2009 06:35AM
O.K. - I finally found a source for A2 steel bar on EBay of all places.
December 31, 2009 04:15AM
Im using linear shaft. (you can buy at the same place where the linear bearings).
It is the best quality.
