Re: Z-axis March 03, 2014 09:03PM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Z-axis March 03, 2014 11:25PM |
Sublime
But with this system the belt can stretch between the roller and the fixed points at the ends
which kind of defeats the purpose of a rack and pinion belt system.
Sublime
most of the motors holding torque would be used up just holding them up.
Re: Z-axis March 04, 2014 12:21AM |
A2
Neat linear drive-guide integration.
Sublime
The available length of belt that can stretch is cut in half with a rack and pinion linear belt (ServoBelt, Belt-on-Belt drive, Tractoring) drive arrangement compared to a static motor.
A2
Sublime
I imagine that there is an on line calculator to help determine how much mass/weight the drive line/transmission/stepper motor could move, and the output torque, force, etc. Josef Prusa calculator is close, probably wouldn't take much to modify it.
Re: Z-axis March 04, 2014 02:37AM |
Sublime
Are you meaning simply because the belt is only half the length it will have half the stretch of a conventional belt system?
I can see how that would be true and an improvement.
Sublime
putting the weight of the motor on the platform would make it really easy to overcome the holding torque.
if this is for a Mendel style machine with the X axis motor and the extruder motor all being held up too I would be really worried.
At that point I think you would need to gear it down.
Re: Z-axis March 04, 2014 05:41AM |
Re: Z-axis March 04, 2014 12:20PM |
Re: Z-axis March 04, 2014 02:07PM |
Re: Z-axis March 04, 2014 02:55PM |
Re: Z-axis March 04, 2014 03:42PM |
Re: Z-axis March 04, 2014 06:55PM |
Re: Z-axis March 04, 2014 07:06PM |
A2
Sublime
If what you are looking for is the system that will give the best surface finish I would go with a belt or cable driven Z axis
Do you have a link that demonstrate how to implement a cable driven Z axis.
Tks.
Re: Z-axis March 04, 2014 09:17PM |
Re: Z-axis March 26, 2014 03:24AM |
Re: Z-axis March 28, 2014 03:22PM |
Re: Z-axis March 29, 2014 11:07AM |
dissidence
i am thinking about going to this type of z axis lift system, but i was thinking about just going to a pulley over a geared stepper, i have one an they are remarkably stiff.
or do you have stl files of your parts there a guy could try to print first.?
