Re: Threadless Leadscrew ??? May 22, 2014 03:56AM |
Re: Threadless Leadscrew ??? May 22, 2014 07:01AM |
Re: Threadless Leadscrew ??? May 22, 2014 11:39AM |
Re: Threadless Leadscrew ??? May 23, 2014 04:13AM |
Re: Threadless Leadscrew more data May 23, 2014 10:35PM |
Re: Threadless Leadscrew ??? May 27, 2014 09:23AM |
Re: Threadless Leadscrew ??? May 27, 2014 12:16PM |
Re: Threadless Leadscrew ??? May 27, 2014 04:19PM |
Re: Threadless Leadscrew ??? May 28, 2014 01:26AM |
) so you would reduce friction compared to a trapezoid acme screw. But the same lead.|
Re: Threadless Leadscrew ??? May 28, 2014 11:47AM |
Re: Threadless Leadscrew ??? May 28, 2014 01:34PM |
dexterm2003
A rubber roller would be good if the rubber coating was really thin. If it gets to thick it will deform and act like a string in the linkage which is not desirable. If it was really thin and the pre-load was relatively high then the it should work really well.
Re: Threadless Leadscrew ??? May 28, 2014 03:00PM |
Re: Threadless Leadscrew ??? May 28, 2014 05:25PM |
Re: Threadless Leadscrew ??? May 28, 2014 06:15PM |
Re: Threadless Leadscrew ??? May 28, 2014 06:45PM |
Re: Threadless Leadscrew ??? May 28, 2014 08:42PM |
Re: Threadless Leadscrew ??? May 29, 2014 05:11PM |
Re: Threaded Leadscrew ??? control June 02, 2014 07:28PM |
Re: Threadless Leadscrew ??? June 05, 2014 03:19AM |
Re: Threadless Leadscrew ??? June 05, 2014 03:53AM |
Re: Threadless Leadscrew ??? June 09, 2014 04:43AM |
Re: Threaded Leadscrew ??? control June 23, 2014 08:44PM |
Re: Threadless Leadscrew ??? June 28, 2014 04:44AM |
