Another Remote Extruder March 22, 2014 12:05AM |
Re: Another Remote Extruder March 22, 2014 09:15AM |
Re: Another Remote Extruder March 22, 2014 10:51AM |
Re: Another Remote Extruder March 22, 2014 10:53AM |
Re: Another Remote Extruder March 22, 2014 12:21PM |
the_digital_dentist
I think it can be made to work. Even if mechanical losses are high, you can use a bigger motor and more current to drive it. If you had to you could mount a set of bearings in the gear to reduce sliding friction along the square rod. It may not be necessary to make the square hole in the gear all that close fitting on the square rod. The whole carriage is going to be moving smoothly on the guide rails anyway.
Yup. Doable!
Re: Another Remote Extruder March 22, 2014 12:30PM |
A2
Idea: To remotely drive the extruder use a flex shaft from a rotary hand tool, e.g. Dremel.
Re: Another Remote Extruder March 23, 2014 04:07PM |
Re: Another Remote Extruder March 25, 2014 11:37AM |
Re: Another Remote Extruder March 25, 2014 12:03PM |
Re: Another Remote Extruder March 26, 2014 02:00PM |
Bill Clark
there is a device called a "ball spline" that does what you are doing above. Typically a grooved round shaft with a bearing that allows rotation with linear travel. I am exploring the idea of using one to move an axis while eliminating the need to carry the mass of the stepper motor.
Re: Another Remote Extruder March 27, 2014 08:37AM |
Re: Another Remote Extruder June 05, 2014 08:25AM |
Re: Another Remote Extruder June 05, 2014 11:19AM |
Re: Another Remote Extruder June 07, 2014 04:42AM |
Re: Another Remote Extruder June 08, 2014 10:03AM |
Re: Another Remote Extruder July 25, 2014 02:25AM |
Re: Another Remote Extruder July 25, 2014 02:50AM |
THE_SHRUB
the_digital_dentist
Yup. Doable!
something like this?
I am planning on using some compact needle roller bearings that will slot into what I am currently calling the "square bearing" which will hopefully keep frictional forces at a minimum while still keeping the weight down. Thx for the suggestion though!
Re: Another Remote Extruder July 29, 2014 08:00AM |
Re: Another Remote Extruder September 16, 2014 09:21AM |
