good source for non-captive linear steppers?
Posted by unfold
March 31, 2014 01:00AM
Hello I am looking for a good source for affordable non captive linear stepper motors, something in the nema17 range. I need at about 150mm usable stroke for driving the plunger down in a syringe, finest pitch so the most possible power is generated.
Preferably in the US, as I am based there for some more months but anywhere else is helpful too!
Thanks!
Re: good source for non-captive linear steppers?
March 31, 2014 05:36AM
"NEMA 17" is the name of a standard for stepper motor mounts. It doesn't even describe what's behind the mounting plate. A "NEMA 17 linear stepper" can't exist, because a mounting plate for a circular stepper doesn't fit a linear one.
March 31, 2014 03:41PM
I don't get your point Traumflug, a Nema 17 sized non-captive linear stepper fits a Nema 17 mount just fine, thats why they are Nema 17 right? They have the exact same face plate dimensions, hole spacing flanges etc as a rotational Nema 17, the fixed axis is just replaced with a threaded rod and internal nut:
[www.haydonkerk.com]
There are round tin-can linear steppers that definitely don't fit on Nema 17 mounts (although there exist optional flanges) but I'm less interested in those although happy to find a source for those too:
VDX
March 31, 2014 04:28PM
... check here - NEMA-8 to NEMA-23: [us.nanotec.com]
But the pricing is heavier than with common RepRap-motors eye rolling smiley
Viktor
March 31, 2014 11:32PM
Thanks a lot Viktor, hand't found that one yet. Thats actually reasonable in price for one from a non-chinese vendor, I can easily find 150$ ones. Thanks a lot, knew you would have a good source smiling smiley
April 01, 2014 12:04AM
I also found this one, which is cheap at 24$, but it is 12V: [www.tdvdesign.com]
I understand that 12V steppers should work but don't perform to their full capacities? What issues can I run into at 12V?
Viktor, I'm having a hard time figuring out what a good one would be. I am not good at understanding all the electronic specs sad smiley
From the RepRap wiki I understand that anything in the 3-5 V and 1-1.5 A ranges should work fine. But I don't see any voltage ratings...
I am looking at this one: [us.nanotec.com]
Maybe model L4118S1404-T6X1, with a 1mm pitch since I need force > speed.
btw I see now that they don't include leadscrews so that makes them a bit less affordable. but ok..
April 01, 2014 06:58AM
unfold
What you show isn't a linear motor. It's a rotatry stepper with a threaded nut integrated. Undoubtly a useful arrangement in some situations, but linear motors work without any spindle.
VDX
April 01, 2014 09:12AM
... this 'linear motor' naming stuff is a bit fuzzy ... call it better linear drive or actuator winking smiley
'Good' steppers for the RepRap-electronics are normally rated with currents of around 2 Amps and corresponding voltages below 5 Volts ... but I have steppers with 325 Volts too, that have realy good dynamic properties ... so this could be different ...
Viktor
April 01, 2014 12:27PM
Traumflug
Now I get it. smiling smiley That makes sense, I was confused by you talking about how it could not be Nema 17...
April 01, 2014 12:51PM
VDX
Thanks for clarifying, I found the linear actuator naming confusing when looking for one that is stepper based since a linear actuator can be so many things, pneumatic, hydraulic. Since I have no engineering education whatsoever I go by Google and a google image search for Linear stepper shows far more images for what I need than a search for linear actuator. spinning smiley sticking its tongue out
VDX
Do I understand well that voltage isn't that relevant?
At Nanotec I can find that the ones I was looking at are specced as 1,4 A/winding, 2 Ohm/winding. Now that leads to 2,8 V/winding right? But what are the correct numbers for the total of the stepper? I am lost here. Help appreciated.
VDX
April 01, 2014 02:59PM
... the essential number is the amperage - with the common bipolar drivers you define the max. current through the coil, then the driver switches the voltage on the coil with a high voltage peak and controls the current to the set value.
The higher the voltage, the faster is the switching/loading of the power, what's defining the dynamic properties.
I'm driving 2V@2A-steppers with drivers, that can output until 70Volts@6Amps without burning the coils by setting the max. current to 2Amps winking smiley
Viktor
April 08, 2014 12:36AM
OK, so got the cheap TDV one with 250mm leads crew TDV linear actuator and installed it on a print head that I made. Adjusted the voltage on the pcb and worked. That was until I actually had it push 60cc of clay through a 1mm nozzle... On and off it skipped steps. So clearly I need a more powerful stepper, combined with maybe the finest pitch screw. I had no idea how to calculate how much pressure I actually needed but today figured something out. Please let me know if this sounds correct:
-I need around 4 bar of air pressure to extrude clay from a 60cc syringe, 6 bar max.
-1 bar = 10 N/cm² so 6 bar = 60N/cm²
-diameter syringe is 28 mm so surface area syringe is ±6,2cm²
-6,2cm² * 60N/cm² = 372N force needed correct?
So, quest open again....
Edited 1 time(s). Last edit at 04/08/2014 12:37AM by unfold.
MPN
May 11, 2014 11:05PM
Just ran across this stepper motor site today, might have what you're looking for:
http://www.omc-stepperonline.com/linear-stepper-motors-c-3.html
July 28, 2016 02:49AM
Did you find your stepper and solve your problem!? I'm currently where you were when you posted this.
I'm looking at nema23's because I feel like the 17's aren't going to cut it for me - my syringe capacity is going to be more like 250-500mL.
I'm totally unsure how to calculate the required force.. did you calculate yours theoretically or not?
Any information you could pass on would be so great
