Printer stops extruding PLA after about one minute, running out of options. May 31, 2014 05:29PM |
Re: Printer stops extruding PLA after about one minute, running out of options. June 01, 2014 05:07AM |
Re: Printer stops extruding PLA after about one minute, running out of options. June 01, 2014 06:10AM |
Re: Printer stops extruding PLA after about one minute, running out of options. June 01, 2014 03:21PM |
Re: Printer stops extruding PLA after about one minute, running out of options. June 01, 2014 09:20PM |
Re: Printer stops extruding PLA after about one minute, running out of options. June 02, 2014 02:58PM |
the_digital_dentist
Check the filament where it is pinched between the gear on the motor and the bearing. Is there a round divot cut into the filament? If so it indicates that the hot-end is jamming. Play with the temperature setting of the hot-end- don't trust the electronics to read the correct temperature unless you can verify it for yourself with a reliable thermometer- either a thermocouple or RTD. If you can adjust the spring tension on the pinch wheel, crank it up. Check the extruder motor current- make sure it has enough- check the temperature of the motor and the motor drive chip- if the chip is getting too hot it may reduce current to the motor to protect itself. If the motor is getting too hot because you're running the current too high the motor will misbehave. It is possible for the motor to get too hot without the driver chip getting too hot, so you must check both of them.
Re: Printer stops extruding PLA after about one minute, running out of options. June 02, 2014 03:20PM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Printer stops extruding PLA after about one minute, running out of options. June 02, 2014 03:27PM |
Re: Printer stops extruding PLA after about one minute, running out of options. June 06, 2014 03:01PM |
Re: Printer stops extruding PLA after about one minute, running out of options. June 07, 2014 07:09PM |
