Re: Help me find a 3dprinter heatbed. November 15, 2014 07:55PM |
the_digital_dentist
Connecting 110V to the printer isn't a good idea because of potential safety problems. In order to be safe you'd have to connect through a transformer, but if you';re going to do that, you may as well use a lower, safer voltage.
Glass plates are fine for unheated beds, but glass is a poor conductor of heat and you'll end up with hot and cold spots. Some people use an aluminum bed to spread the heat and then use thin glass plates on top of the aluminum to print. That allows you to take a finished part and plate off the printer and replace it with another piece of glass while the first one goes into a freezer to release the printed part.
Re: Help me find a 3dprinter heatbed. November 18, 2014 12:28PM |
[/quote]Quote
cozmicray
Current Kills NOT voltage!!
Re: Help me find a 3dprinter heatbed. November 18, 2014 12:36PM |
Re: Help me find a 3dprinter heatbed. November 18, 2014 03:16PM |
Re: Help me find a 3dprinter heatbed. November 21, 2014 07:13PM |
cozmicray
jaguarking11
Point taken -- you sound like an electrical engineer
Please comment on the use of a 120V AC heated bed on a 3D printer
since the expert, the_digital_dentist, has stated that it isn't a good idea?
Thanks
Re: Help me find a 3dprinter heatbed. November 29, 2014 04:36PM |
Re: Help me find a 3dprinter heatbed. November 29, 2014 06:51PM |
Re: Help me find a 3dprinter heatbed. December 01, 2014 05:51PM |
Re: Help me find a 3dprinter heatbed. December 05, 2014 12:00PM |
Re: Help me find a 3dprinter heatbed. December 05, 2014 12:53PM |
Re: Help me find a 3dprinter heatbed. December 05, 2014 01:31PM |
There was a thread just the other day that asked almost the same question. If you really need 7 steppers, Deut with Duex4 was the only one that I knew of. If any of those 7 steppers could be doubled up (e.g. dual lead screws for the z-axis) then you have a few more options with 6-stepper electronics.Quote
nick6765
I would like my 3d printer to have 7 stepper motor
Re: Help me find a 3dprinter heatbed. December 05, 2014 03:47PM |
Re: Help me find a 3dprinter heatbed. December 06, 2014 06:54PM |
Re: Help me find a 3dprinter heatbed. December 06, 2014 11:37PM |
Re: Help me find a 3dprinter heatbed. December 16, 2014 05:07PM |
Re: Help me find a 3dprinter heatbed. December 17, 2014 12:18AM |
Re: Help me find a 3dprinter heatbed. December 17, 2014 03:24AM |
Re: Help me find a 3dprinter heatbed. December 19, 2014 08:17AM |
Re: Help me find a 3dprinter heatbed. December 19, 2014 09:03AM |
Offtopic for this thread, but google is your friend. Or ebay, aliexpress, McMaster-Carr, Mitsumi, etc... You'll probably want to search for metric lengths when specifying metric rods. 1m 1.5m, are probably going to be your most likely length options and then cut them down, but you may need to go up to a 2m rods if you can't find any at 1.5m for the 55" length.Quote
nick6765
Does anyone know were i can buy online this things,
smothrod m8 hardened steel height 55" and 35"
Threadedrod m8 steel height 55"
Re: Help me find a 3dprinter heatbed. December 31, 2014 05:27PM |
Re: Help me find a 3dprinter heatbed. December 31, 2014 10:12PM |
Re: Help me find a 3dprinter heatbed. January 19, 2015 10:05PM |
I have used 240 volt heated beds on over 70 builds with no problems at all. The power is switched by a SSR which is controlled by RAMPS the same way a 12 volt heated bed is attached.Quote
the_digital_dentist
Re: Help me find a 3dprinter heatbed. January 20, 2015 12:28AM |
Re: Help me find a 3dprinter heatbed. January 27, 2015 12:27PM |
Re: Help me find a 3dprinter heatbed. February 10, 2015 03:46PM |
Re: Help me find a 3dprinter heatbed. February 20, 2015 04:33AM |
Re: Help me find a 3dprinter heatbed. February 20, 2015 06:39AM |
ocina
I just realize something,why cant i just buy lots of small heatbed tell i reach the dimmesion i want and place aluminum on top of them.
