Bed bearings explanation
Posted by ArmatkaPL
February 05, 2015 03:28PM
Hello guys!
I've got some question regarding bed frame bearings. Why use 3 not 4? Wouldn't it be more stable then?
Re: Bed bearings explanation
February 05, 2015 04:56PM
Hello,
Four bearings can cause binding. See also [forums.reprap.org]
February 09, 2015 11:07PM
Some commercial printers come with four bearings (Printerbot is one that comes to mind right away). A friend has a RepRap with four on Y and he claims it experiences zero binding. I am designing a RepRap with a Y carriage that can use four or three bearings. First I will try four. If that doesn't work I can easily switch to three. Correctly aligned I believe four should work just fine. At least I want to test if I can align the bearings properly. If not, it will be a painless experiment.
New browser from the creator of Opera: [vivaldi.com]
February 10, 2015 07:48PM
Technically speaking, 4 bearings is an "over-constrained mechanism". Two bearings on one rail insure motion along the rail's axis. Adding a third bearing on a second rail parallel to the first prevents rotation around the first rail/axis, thus constraining the motion completely. Adding a fourth bearing does nothing to further control the motion unless you consider a carriage that is not perfectly stiff.
Three or four bearings can be made to work fine, though misalignment when using four is less forgiving - i.e. more likely to bind- than the same misalignment with only three bearings.
