Parts for a belt driven extruder in the UK? February 12, 2015 06:38AM |
Re: Parts for a belt driven extruder in the UK? February 12, 2015 10:12AM |
Re: Parts for a belt driven extruder in the UK? February 12, 2015 12:47PM |
Re: Parts for a belt driven extruder in the UK? February 12, 2015 06:21PM |
Re: Parts for a belt driven extruder in the UK? February 13, 2015 04:27AM |
3dkarma
I have searched high and low for these in the UK and not been able to find any. I had to resort to ordering from China through AliExpress.
Re: Parts for a belt driven extruder in the UK? February 16, 2015 06:05PM |
Re: Parts for a belt driven extruder in the UK? February 17, 2015 06:02AM |
3dkarma
My belts only just arrived. I'm planning on modifying the Wade's. Pulleys are also difficult to source, so I'll be printing the larger pully. I'll use a standard 16 tooth pulley and marry it with an 80 tooth printed pulley, to give me a 5:1 drive ratio.
Re: Parts for a belt driven extruder in the UK? February 17, 2015 08:45AM |
Re: Parts for a belt driven extruder in the UK? February 17, 2015 09:03AM |
jaguarking11
The whole point of a belt drive is to increase the retraction speed and possibly the precision. If your running a 5:1 or 4:1 ratio there will still be some problems. Do you really need so much torque? I find my belt driven extruder with a 2:1 ratio works very well in the 150mm/s range with 1.75mm filament. I have retraction set at 200mm/s in the 3.5mm range and this is for a bowden setup. Artifacting due to blobs etc has been minimal at best. I would suggest you guys try a 2:1 setup or even a 2.5:1 given you already have a 16T pulley. If you find your lacking torque its not the gear reduction fault but something else like lack of precision or tuning.
My .02c on the matter. One more thing I would suggest is to get rid of the hobbled bolts and use a precision ground 5mm shaft coupled to a mk7 gear to increase precision. Most of these hobbled bolts were not machined well, nor are bolts designed to be very true or round to begin with. At least not the ones I have seen......
Re: Parts for a belt driven extruder in the UK? February 17, 2015 09:28AM |
Re: Parts for a belt driven extruder in the UK? February 17, 2015 10:50AM |
Re: Parts for a belt driven extruder in the UK? February 17, 2015 11:54AM |
Re: Parts for a belt driven extruder in the UK? February 17, 2015 01:40PM |
jaguarking11
Spacing is not critical. I prefer the MK7 gear as its better suited for 1.75mm filament. Number of teeth does not make a difference, you can have a long belt. However tension does matter. I have my extruder under allot of load as far as the belt goes. I can barely feel any give between the two pulleys. You can get a 40T GT2 pulley with 5mm bore just about anywhere in the world through e-bay etc etc. They are a bit pricy for a simple alu pulley but they are worth it.
As for grinding a flat spot? I have not needed to do so on my own setup. I dip the screw in ABS slurry and crank it down hard. I may do this if this becomes a problem but as of now it has not as the pulleys I use both have two set screws in them. The MK7 gears I use are stainless and therefore I can crank down on them very hard. The main thing is that the shaft has to be steel. Alu shaft is not adapt. Hardened drill rod steel is what I use.
Re: Parts for a belt driven extruder in the UK? March 06, 2015 03:23PM |
Re: Parts for a belt driven extruder in the UK? March 06, 2015 05:32PM |
jaguarking11
Did you build your extruder? How did it come out if you built it.
Re: Parts for a belt driven extruder in the UK? March 12, 2015 05:51PM |
Pointy
jaguarking11
I have it part assembled, but I am waiting for the 40T pulley and belt which have finally left China. Had to print some parts again after tweaking the files as the holes came out quite a bit under size. ( I think it's a problem with Slic3r when you do infill before perimeters) It went together pretty easy, I just had a little trouble with the push fitting but managed to find a tap of the right size.(maybe because PLA is harder than ABS?) I did find it a little fiddly to feed the filament, but it certainly seems to grip it nicely when I turn the knob by hand.
I post some pics when I get a chance.
Regards,
Les
Re: Parts for a belt driven extruder in the UK? July 23, 2016 06:08AM |
jaguarking11
Pointy
jaguarking11
Regards,
Les
Awesome! I cant wait to hear your thoughts for good or bad. As for fiddly, thats a compromise I made on having the feed hole slightly offset from the gear. This allows for a mild wrap that gives it a bit more grip. As for holes under size, internal holes almost always come undersize when 3d printing. I usually clean them up with a drill bit. Hoping your as happy with it as I am. Its my baby afterall.
extruder.hotend.default_feed_rate 600 # Default rate ( mm/minute ) for moves where only the extruder moves extruder.hotend.acceleration 500 # Acceleration for the stepper motor, as of 0.6, arbitrary ratio extruder.hotend.max_speed 200 # mm/s
Re: Parts for a belt driven extruder in the UK? July 26, 2016 03:04PM |
Pointy
jaguarking11
Pointy
jaguarking11
Regards,
Les
Well over a year later and I finally put it together.
If you are still around jk11, I have a couple of questions...
I have done a very quick calibration and it has come out at 204 steps per mm. Does this sound about right?
I am using a Smoothieboard and am unsure what to set the following settings to, any suggestions?
Regards,
Les
Re: Parts for a belt driven extruder in the UK? July 26, 2016 03:39PM |
jaguarking11
Hey. im glad you got yours going. The steps per/mm sound about right. I would do this if I were you. Unplug your hot end and trim the filament flush with the bowden. Then command the extruder to extrude 100mm of plastic. Then measure from the edge of the tube to the tip of the filament. Then simply take your knowsn steps in this case 208 then multiply it by desired distance which is 100 then divide by measured distance which lets for arguments sake say its 93, so your new steps per mm would be 223 or so. Hopefully this makes sense to you.
-Bruno
Re: Parts for a belt driven extruder in the UK? July 26, 2016 04:26PM |
Pointy
jaguarking11
-Bruno
Well, it's not technically going yet, but pretty close.I am just in the middle of adding a heated bed and tidying up a few bits, but hopefully I will get to print something soon!
I am ok with calibrating the steps thanks, I wasn't sure about the other settings posted, I am not even sure if they are applicable to a delta.
On a side note, how are you finding the hall effect sensors? I saw your article and I have ordered some to play with.
Regards,
Les
Re: Parts for a belt driven extruder in the UK? July 30, 2016 05:56PM |
jaguarking11
The sensors have been flawless. No issues to report honestly. I plan on using them on my CNC mill build as well. They seem very accurate and more importantly they are repeatable.
Re: Parts for a belt driven extruder in the UK? August 02, 2016 09:55AM |
Re: Parts for a belt driven extruder in the UK? August 08, 2016 04:51AM |
jaguarking11
I would not put that curve on the output. I think a straight shot is a much better way out the extruder as it reduces friction. PTFE tubing is used to get the radious curves you may or may not need. My .02c, this is a truely open design so you can do whatever you like.
jaguarking11
As for the magnets. Mine are in the 3x5mm cylinder size. My advice is to mount the sensors on the body of the printer and have the magnets on the moving parts of the printer with some form of adjustment. The adjustment can be as simple as a M3 Bolt on an L bracket with the magnet super glued to the tip. This way you turn your bolt and adjust the printer, I would even go as far as putting a a nut on the bolt so you can lock it in place. ABS slurey makes a great thread locker for these printers, its impervious to vibrations but breaks free easily and cleanly from the threads when forced. Consider it a very mild thread locker.
Re: Parts for a belt driven extruder in the UK? August 08, 2016 01:05PM |
Re: Parts for a belt driven extruder in the UK? August 25, 2016 04:35PM |
Re: Parts for a belt driven extruder in the UK? August 25, 2016 05:52PM |
jaguarking11
I have been on vacation for some time. Love the look of the extruder in your setup. I see you kept the faucet handle![]()
I would love to test out your version of the extruder. I have been thinking of making a direct drive version as well for those who dont mind adding 200G to their carriage.
Let me know when you upload it.
