China NEMA17 Stepper Motor Torque Rating Scam July 18, 2015 02:58PM |
Re: China NEMA17 Stepper Motor Torque Rating Scam July 18, 2015 03:03PM |
Re: China NEMA17 Stepper Motor Torque Rating Scam July 18, 2015 03:05PM |
Re: China NEMA17 Stepper Motor Torque Rating Scam July 18, 2015 03:13PM |
Re: China NEMA17 Stepper Motor Torque Rating Scam July 18, 2015 03:22PM |
Re: China NEMA17 Stepper Motor Torque Rating Scam July 18, 2015 03:30PM |
Re: China NEMA17 Stepper Motor Torque Rating Scam July 18, 2015 03:36PM |
Re: China NEMA17 Stepper Motor Torque Rating Scam July 18, 2015 04:22PM |
Re: China NEMA17 Stepper Motor Torque Rating Scam July 18, 2015 09:32PM |
Re: China NEMA17 Stepper Motor Torque Rating Scam July 18, 2015 10:15PM |
Re: China NEMA17 Stepper Motor Torque Rating Scam July 18, 2015 10:41PM |
Re: China NEMA17 Stepper Motor Torque Rating Scam July 19, 2015 03:25AM |
Re: China NEMA17 Stepper Motor Torque Rating Scam July 19, 2015 08:02AM |
assuming linear proportion, the holding torque should be 5/3.5 = 1.42kg.cm very close to what i got of the stepper motor. the stepper rating should be ok, so for now my first claim is busted.
Re: China NEMA17 Stepper Motor Torque Rating Scam July 19, 2015 08:27AM |
Re: China NEMA17 Stepper Motor Torque Rating Scam July 19, 2015 08:51AM |
Re: China NEMA17 Stepper Motor Torque Rating Scam July 19, 2015 11:27AM |
i managed to burn one of the module earlier by just slightly adjusting it, yet torque improvement is almost nonexistence from hand twist resistance feel test. i used 12V power supply. thanks for the link... but $36 per stepper is quite expensive for my taste since i have 8 steppers in my design and at least 4 of them (Z axes) require high torque. i try cheaper option first before anything, thanks.Quote
the_digital_dentist
All the little stepper driver modules I've seen that look like the ones you have, have a small pot to adjust the current. You should be able to get more than 0.57A from them. What is the power supply voltage that you're using for this test?
I use a pair of these drivers with 32V power supplies to drive the X and Y axis NEMA-23 motors in my printer.
thanks for the link. to be frank, i'm quite hesistant to believe whats written on paper (stepper's spec in ebay), but i can use that as initial design info when the items in delivery. but when something fishy like what i've experienced, i will conduct "practical" or "empirical" test, the result, thats what i will believe 100% and use in the next redesign. i tested both static rotor EN on (holding torque only) and very slow rotation at 16th microsteps, the stepper can hold on the air or lift up 1kg load happily at 1cm radius... since this is torque priority, i will setup anything possible to maximize it, even if i have to use full step only and reduce the speed. but iirc i did test full step vs 16th microstep earlier, torque strengths were almost identical from "hand twist resistance feel test".Quote
alan richard
According to microstepping-myths-and-realities
Suggesting that your 1kg.cm is quite high really.
-a
Re: China NEMA17 Stepper Motor Torque Rating Scam July 19, 2015 12:24PM |
Re: China NEMA17 Stepper Motor Torque Rating Scam July 20, 2015 12:55AM |
Re: China NEMA17 Stepper Motor Torque Rating Scam July 20, 2015 08:01AM |
Re: China NEMA17 Stepper Motor Torque Rating Scam July 20, 2015 11:22AM |
Re: China NEMA17 Stepper Motor Torque Rating Scam July 25, 2015 01:12PM |
