stepper motor wiring & color codes
Posted by owad
October 03, 2007 07:40PM
I couldn't find this in the wiki and spent a lot of time digging around in data sheets, so I figured I'd post it here to save others some time.
Nanotech ST5709S1208-B:
A+	Red
A-	Black
B+	Green
B-	Yellow
SureStep STP-MTR-23055:
A+	Red
A-	White
B+	Green
B-	Black
Stepper board pinout:
Pin (Y & Z axes)	Pin (X axis) 	                Term
1 				4 			A+
2				3			A-
3				2			B+
4				1			B-
SureStep STP-MTR-23055 wiring
1 				4 			Red
2				3			White
3				2			Green
4				1			Black
Dear Sir,
I need to learn how to find stepper motor colour combination by measuring resistance with multimeter.thanks
Best regards,
JK
Re: stepper motor wiring & color codes
March 15, 2009 06:22AM
The colours for several types of stepper motor are here:
[reprap.org]
which tells you the ABCD colours: and then the board connectors are here:
[reprap.org]
I am having a step syn stepper motor from Sanyo Denki. Its model number is 103H8582-8044 and its Lot number is 09722. It has five colors namely Blue, Yellow, Red, Orange and Black. I dont know the sequence of those colors. Please tell me the sequence, that is in which order should i connect the stepper motor. Please reply to me as soon as possible.
April 01, 2009 03:28PM
Your answer is on the Sanyo Denki webpage
[www.sanyo-denki.com]
But here is the summary
Orange and Blue are one set of wires
Red and Yellow are the other set
Black and white are the commons (white may be tied internally)
Clockwise full step firing order is
Red Blue
Blue Yellow
Yellow Orange
Red Orange
I'll let you figure out the half step order
> Lot number is 08410. It has five colors namely
> possible.
Sir,
i have with me SMC44G nanotec stepper motor controller. I want to understand the connection details of the terminal strip on this controller and its sequence of operation. also the dip switches signifance. If you could post me the datasheet of this module it would be better.
Expecting a immediate reply.
with regards
SS Shetty
April 24, 2009 03:41PM
All of the documentation I see on the smc44g is in German, which isn't my native language so I can only roughly translate the following pdf file at:
[en.nanotec.com]
It's a 0 to 40kHz bipolar chopper for 5v or 24v bipolar steppers
The motor wires plug into the A, A/, B, and B/ on the right hand side of the controller. The 24V input power and ground go underneath those.
On the left side you get to pick if you want a 24V or 5V drive. The clock for which one you are using, and the direction.
I think the right and left sides are pretty obvious to english speaking people.
Now for the part where you need german.
The top row of 8 dip switches are divided into 3 groups
Group 1 is the first 3 dip switches and they control the stepping. See the pdf
under schalter 1 bis 3
Vollschritt is Full step
Halbschritt is half step
Viertelschritt is 1/4 step
Funftelschritt is 1/5 step
Achtelschritt is 1/8 step
Zehntelschritt is 1/10 step
Group 2 is dip switches 4-7 and they specify the amperage limit see the pdf for those settings. Set it to the limit or a bit under the limit of your motor.
Group 3 is pin 8 and it is the enable switch. Up position is enable (on), down position is disabled (off)
Anyone else who can read german and do a better translation, feel free to correct anything I have translated incorrectly - my technical german is pretty rusty.
stepper motor
September 19, 2009 12:43PM
cd rom used stepper moto???
sun zuo fu
December 01, 2009 12:23AM
sir
i have some dificulty of uxing pmm5310,this is a hic of sanyo denki for drving 5 phase stepping motor,but,i can not find the datasheets of it ;
who can help me?
a fan of electronics ,qingdao shandong province china ;
my e-mail:[email protected]
January 08, 2010 03:48AM
Dear All
I would like to get some information on microcon stepper motor sx17-0804 wiring color indentifications.
Thank you.
suresh
Re: stepper motor winding
January 18, 2010 04:26AM
we have stepping motor type 103H7523-8053 lot.no.6037778-1
Please give me winding Instruction
Thanks
Suresh
January 18, 2010 08:34AM
Acording to a Google search it is this stepper :-
Guiqiu Sanyo Electric model 103H7523-8053
Other results indicated it is discontinued model.
So trying a search of the [www.sanyo-denki.com] site would be your next step using google.
Bodge It [reprap.org]
BIQ Sanguinololu SD LCD board BIQ Stepcon BIQ Opto Endstop
BIQ Heater Block PCB BIQ Extruder Peek clamp replacement BIQ Huxley Seedling
BIQ Sanguinololu mounting BIQ standalone Sanguinololu or Ramps mounting Print It Stick It Cut it
My rep strap: [repstrapbertha.blogspot.com]
Buy the bits from B&Q pipestrap [diyrepstrap.blogspot.com]
How to Build a Darwin without any Rep Rap Parts [repstrapdarwin.blogspot.com]
Web Site [www.takeaway3dtech.com]
pari
January 22, 2010 11:36AM
Hello Sir,
I have a step syn stepper motor of type 103H7121-0140 and lot number 06917
can you give me the wiring order and color codes of this.
January 22, 2010 12:12PM
This isn't a forum for helping random people from the internet use stepper motors. This forum relates to RepRap. If you want help with a specific stepper for something other than RepRap, you really should try Googling it or asking somewhere else.
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing.
Anyone can edit the wiki!
Hi I have just bought a cnc router with zapp sy60sth66 3008bf stepper motors none of which are conected.
I have 4 wires
(1) red/White
(2) green/white
(3) black/white
(4) blue/white
On the driver board it states A+ A- B+ B- can anybody tell me what wires go where.
Many thanks Wendy
January 24, 2010 08:36AM
Try shorting two wires together until you find a pair than makes the motor much stiffer to turn. Connect that pair to A+/A- and the remaining two to B+/B-.
If the motor turns the wrong way reverse one pair.
I tried this; it seems there are 2 pairs that make the motor harder to turn both equally harder. Does it matter with pair I call A+ A-.
Cheers Wendy
VDX
January 26, 2010 09:38AM
Hi Wendy,
... you change the moving direction when reversing one coil - so you can screw the according pairs in the terminals, test, and reverse later, if the motor turns the wrong way ...
Viktor
Dear sir,
i bought a six wired stepper motor in which it is written M42 SP-3 and the company name is MITSUMI .i couldnt find the data sheet as well as its colour code.the colour of the wires are yellow,blue,red,white and two green.kindly help me.
i have stepper motor.which code is 55SIM-25DAYG stepper motor but i don't know company name.i required polarity of the stepper motor like A+,A-,B+,B-,common.the colour code of the wire is
white
red
blue
brown
yellow
so,please give me solution of my query in my id immediatly
I have M42SP-5 unipolar stepper motor.I want to know the color cambination.
Thanks
Red is common. Rest are Brown, Black, Orange , Yellow.
Aslam Wrote:
> Dear sir,
> me.
February 12, 2010 03:51PM
I bought 4 used steppers on Ebay. They are described as:
Type 103H5208-0842
Sanyo Denki
2.0 OHM
STEPPER MOTOR, 1.8 deg 200 steps/rev when full-stepping
Description of their wiring was as follows:
RED = A
BLUE= B
YL = A-
ORG = B-
BLK = COMMON
WHT = COMMON
My problem is that the wires are all the same color on the actual motors so it doesn't do me any good. Can anyone describe how to test the wiring to determine which wire on a stepper motor does what?
Thanks
hi
i had two stepper motor
but i could not use them
becuse color wiering i dont mean
colors is yellow - red - brown - white - blue
tank help me
sreenath Wrote:
> Aslam Wrote:
> > Dear sir,
> name
> well
> > me.
March 27, 2010 11:43AM
I can't get my "brand new" NEMA23 KL23H251-24-8B to work.
Can someone explain how I should be wiring them to the reprap stepper driver?
dear sir,
i recently bought a 6-wire stepper motor and i don't know how to wire it.
it has a brown,blue,white,black,red and yellow wire.can anybody tell me how i should wire it and the control sequences to be applied to turn it clockwise and anticlockwise. BIG THNX in advance.confused smiley
April 28, 2010 06:01PM
Examine the handy-dandy wiki page I just made in answer to your question.
stepper wiring wiki page
I figure it's the fourth time I've answered that question, time to make a wiki page. So I did.
I'm building it with Baling Wire
