Mounting square linear bearing/guide on 4040 aluminum extrution October 06, 2015 09:26PM |
Re: Mounting square linear bearing/guide on 4040 aluminum extrution October 07, 2015 08:13AM |
Re: Mounting square linear bearing/guide on 4040 aluminum extrution October 07, 2015 09:51AM |
Re: Mounting square linear bearing/guide on 4040 aluminum extrution October 09, 2015 11:38AM |
Re: Mounting square linear bearing/guide on 4040 aluminum extrution October 09, 2015 12:18PM |
Re: Mounting square linear bearing/guide on 4040 aluminum extrution October 09, 2015 01:35PM |
You can mount linear rail to extrusion just fine. The required flatness for linear rail mounting is only necessary to guarantee their accuracy specs, its not like the rail will bind if you bolt it to extrusion.
You can get milled extrusion for Misumi that is explicitly intended for linear rail but I'm not convinced it will achieve anything given the accuracy requirements and rigidity of a typical 3d printer.
On a related note, I would always recommend Misumi extrusion instead of 8020.
Re: Mounting square linear bearing/guide on 4040 aluminum extrution October 09, 2015 08:22PM |
