Direct Drive 1.75 mm -- Not Enough Torque? October 19, 2015 12:40AM |
Re: Direct Drive 1.75 mm -- Not Enough Torque? October 19, 2015 04:02AM |
#define DISABLE_E false // For all extruders
Re: Direct Drive 1.75 mm -- Not Enough Torque? October 24, 2015 06:13AM |
Re: Direct Drive 1.75 mm -- Not Enough Torque? November 19, 2015 03:43PM |
Re: Direct Drive 1.75 mm -- Not Enough Torque? November 19, 2015 05:40PM |
Re: Direct Drive 1.75 mm -- Not Enough Torque? December 19, 2015 10:25PM |
Seriously. Way overkill.Quote
dc42
I did some research on this and I came to the conclusion that in order to get a 1.75mm direct drive extruder to work well, you need to get several things right:
1. A long (48mm or longer) stepper motor, assuming it is a Nema 17. Shorter motors have insufficient torque.
2. Run the stepper motor close to its rated current, e.g. at 85 or 90%. This requires the stepper motor to be carefully chosen so that standard stepper drivers can handle that current.
3. A hobbed pulley in good condition with lots of grip.
I find it easier to use 3:1 geared extruders and smaller motors.
Re: Direct Drive 1.75 mm -- Not Enough Torque? December 20, 2015 01:20AM |
Re: Direct Drive 1.75 mm -- Not Enough Torque? December 20, 2015 08:37AM |
I believe it's important to note how temperatures in consumer 3D printers are inaccurate in general. Or at least should be considered inaccurate untill proven otherwise.Quote
the_digital_dentist
I think it's important to recognize that the temperature readout may not be accurate. If it says it's 220C but it's actually 180C, you will run into problems extruding. If you have a thermocouple and a DMM you can check to see if the temperature is close to what the printer controller reports. If you don't have a thermocouple, try turning up the temperature before deciding that the extruder is the problem.
